heat transfer convection boundary condition
Old   August 8, 2016, 05:06
Default heat transfer convection boundary condition
JohnJohn8 is on a distinguished road
Dear all,
I am new to OpenFoam and I want to simulate a block which is cooled by convection at a surface and I am interested in the heat conduction in the block. After research, I found the boundary type: convectiveHeatTransfer, after inputting in as patch type and try to run laplacianFoam I got an error. This error stated that the patch type was unknown. After looking into the source code I saw that the patch type is included in the source code, but only in turbulence sections. Is this patchtype on applicable to turbulent flow settings?
Thanks in advance.
Kind regards
JohnJohn8 is offline   Reply With Quote
Old   August 8, 2016, 11:39
Mahdi Hosseinali
anishtain4 is on a distinguished road
As you can see from the patch it's meant for the compressible RAS simulation were it provides the h.
For your case it is q=ha(Tb-Tf), q=kaDT/Dn => kDT/Dn=h(Tb-Tf)
This is a mixed boundary condition. You need to know h.
anishtain4 is offline   Reply With Quote
Old   August 9, 2016, 06:35
Dear Mahdi,
Thanks for your response.
How exactly do I have to apply this boundary?
Because there is only the thermal diffusivity in the constant folder, how could I specify all the constants?
Thanks in advance.
Kind regards.
Old   August 11, 2016, 06:00
Alex
zfaraday will become famous soon enough
Hi John,
You can check out my web site where I talk about what you need to learn, I think you may find it useful. Besides that, you can also find a further explanation on what Mahdi says in this document, also located in my web.
Hope it helps,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   August 11, 2016, 11:48
Mahdi Hosseinali
I understand there would be a duplicate of thermal diffusivity, both in constant folder and your boundary condition. But usually this is not that big of a hassle to need to develop your own boundary condition for it. Specially if don't have much experience in OF programming.
boundaries condition, heat and mass transfer
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
