August 3, 2016, 13:23 |
Axisymmetric simpleFoam convergence issues
Graham
Rep Power: 10 |
Hi there,
I am using simpleFoam to simulate axisymmetric flow in a channel. I cannot get my solution to converge because the solver tries to solve for the third velocity component (Uz) unsuccesfully (residuals attached as pdf). I have found previous posts on this such as: http://www.cfd-online.com/Forums/ope...component.html and http://www.cfd-online.com/Forums/ope...ric-cases.html However, there appears to be no fix for this unless I manually force the solver to avoid solving for Uz (which I don't know how to do). This seems surprising for such a simple case! Does anyone know how to get around this? My blockMeshDict looks like: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; L 10.0; zvalp 0.1; zvaln -0.1; yval 0.994987; vertices ( (0 0 0) ($L 0 0) (0 $yval $zvaln) ($L $yval $zvaln) ($L $yval $zvalp) (0 $yval $zvalp) ); blocks ( hex (0 1 3 2 0 1 4 5) (50 50 1) simpleGrading (1 0.1 1) //switch x and y ); edges ( arc 2 5 (0 1.0 0) arc 3 4 ($L 1.0 0) ); boundary ( front { type wedge; faces ( (0 1 4 5) ); } back { type wedge; faces ( (0 1 3 2) ); } tankWall { type wall; faces ( (2 3 4 5) ); } inlet { type patch; faces ( (0 2 5 0) ); } outlet { type patch; faces ( (1 3 4 1) ); } axis { type empty; faces ( (0 1 1 0) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // |
August 14, 2016, 08:42 |
Artur
Rep Power: 20 |
Have you tried the wedge boundary condition? It's explained here: http://cfd.direct/openfoam/user-guide/boundaries/ All the best, A |
August 15, 2016, 06:47 |
Graham
Rep Power: 10 |
Dear Artur,
I am already using the wedge boundary condition - see blockMeshDict above. Any other suggestions? Best regards, Graham |
2D Hypersonic Inlet in FLUENT - Convergence Issues | Fraisdegout | FLUENT | 6 | December 15, 2016 02:07 |
Tutorial on Fluidized Bed has convergence issues | luca.delbene | STAR-CCM+ | 0 | December 2, 2014 06:05 |
Convergence issues for steady turbulent diffusion flame | stuntmanmike | CFX | 5 | November 7, 2014 17:37 |
SimpleFoam convergence problem with really simple simulation | mayank.dce2k7 | OpenFOAM Running, Solving & CFD | 2 | November 19, 2013 05:28 |
Convergence rate of SimpleFoam | boddyouareboy | OpenFOAM | 0 | January 25, 2011 03:49 |
