Residual control
Old   August 1, 2016, 11:24
Default Residual control
Felix
fimbull is on a distinguished road
Well i have a case, in which i will reduce the runtime.
I am using the interPhasechangeDyM Solver
I allredy have reduced the runtime from 100% to 33% with improving the pressure iteration speed.
My Problem is that im iteration the variable p_corr.
In that case I am using these specs below
"pcorr.*"
        solver          GAMG;
        tolerance       1e-4;
        relTol          0;
        smoother        DICGaussSeidel;
        cacheAgglomeration no;
        nCellsInCoarsestLevel 20;
        agglomerator    faceAreaPair;
        mergeLevels     1;
PIMPLE
    momentumPredictor          no;
    correctPhi          yes;
    nOuterCorrectors    7;
    nCorrectors         1;
    nNonOrthogonalCorrectors 10;
    residualControl
        p_rgh
            tolerance 1e-7;
            relTol 0;
            absTol 0;
in the first Timestep im getting this
Execution time for mesh.update() = 2.69 s
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 7.030918589e-05, No Iterations 15
GAMG:  Solving for pcorr, Initial residual = 0.1618379063, Final residual = 9.09515451e-05, No Iterations 5
GAMG:  Solving for pcorr, Initial residual = 0.03177132081, Final residual = 3.050995536e-05, No Iterations 5
GAMG:  Solving for pcorr, Initial residual = 0.01138752385, Final residual = 5.915332199e-05, No Iterations 3
GAMG:  Solving for pcorr, Initial residual = 0.004623339973, Final residual = 4.032533298e-05, No Iterations 3
GAMG:  Solving for pcorr, Initial residual = 0.002091591789, Final residual = 2.678131328e-05, No Iterations 2
GAMG:  Solving for pcorr, Initial residual = 0.000935694126, Final residual = 6.876109491e-05, No Iterations 1
GAMG:  Solving for pcorr, Initial residual = 0.0004440894954, Final residual = 3.892454402e-05, No Iterations 1
GAMG:  Solving for pcorr, Initial residual = 0.0002179582446, Final residual = 2.564707496e-05, No Iterations 1
GAMG:  Solving for pcorr, Initial residual = 0.0001126573963, Final residual = 1.363380582e-05, No Iterations 1
GAMG:  Solving for pcorr, Initial residual = 5.807458978e-05, Final residual = 5.807458978e-05, No Iterations 0
time step continuity errors : sum local = 3.835607192e-09, global = 8.465794602e-12, cumulative = 8.465794602e-12
but in the most timesteps after this im getting this
Execution time for mesh.update() = 2.72 s
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 9.089048299e-05, No Iterations 28
GAMG:  Solving for pcorr, Initial residual = 0.0002686212536, Final residual = 4.119209357e-05, No Iterations 1
GAMG:  Solving for pcorr, Initial residual = 7.742703334e-05, Final residual = 7.742703334e-05, No Iterations 0
time step continuity errors : sum local = 1.8005001e-05, global = 4.661703486e-06, cumulative = 4.661711952e-06
Is there any possibility to set a convergence criteria that is only responssible for p_corr and can reduce my -Zero Iterations-?
fimbull is offline   Reply With Quote
Old   August 2, 2016, 09:04
Felix
What i exactly mean is the following:
is there any residual criteria for the nNonOrthogonalCorrectors?
I dont wanna do additional iterations loops, when the nNonOrthogonalCorrectors allready have reached the residuals.
fvsolutions, gamg, iterations, pimple, p_corr
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
