Time-averaging of fields doubt
Old   July 31, 2016, 13:07
Question Time-averaging of fields doubt
Max Vorstadt
jet_engine is on a distinguished road
Hi! I would like to ask a question regarding the time-averaging of the main fields of a simulation. Let's say I have a simulation running from time 0 to 1 seconds, but the results did not converge for enough time yet so I want to run it up to 1.5 seconds to prove the convergence.
My controlDict looks like this:
functions
meanValues
        type            fieldAverage;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled                 true;
        cleanRestart            false;
        outputControl           outputTime;
        resetOnOutput           false;
        resetOnRestart          false;
        fields
            U
                mean        on;
                prime2Mean  off;
                base        time;
My two questions are:
  • How can I indicate that I want it to average from 0.7 (let's say here it begins to converge) and up to 1.5 seconds?
  • If I am already at time 1 seconds and I indicate that the average begins at 0.7, will it work or does it need to average from the moment the simulation is (re)started? I mean, in my case, does it need to start at t=1 if I'm at that point already or can I restart the simulation at t=1 but also starting the average taking into account previous values (from t=0.7)?
Thanks in advance!
jet_engine is offline   Reply With Quote
averaging, controldict, field average, mean flow field
Elastic or Plastic Deformations in OpenFOAM NickolasPl OpenFOAM Pre-Processing 36 September 23, 2023 09:22
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
[solidMechanics] solidMechanics gear contact in rotation nlc OpenFOAM CC Toolkits for Fluid-Structure Interaction 3 January 11, 2015 07:41
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
