DPMFoam diverged when inject particles with high "nParticle"
Old   July 30, 2016, 04:03
Default DPMFoam diverged when inject particles with high "nParticle"
Bijan Darbari
bijan darbari is on a distinguished road
Dear Foamers
I was doing simulation of water laminar flow between two parallel plates and 100nm particles injected from a point in center of channel. DPMFoam solver used.
If I set "coupled true;" in kinematic cloud and set high value for "nParticle" ( for exmaple "nParticle 1e8;" ) the courant number increased and the solver diverged after some iteration.
But for low value of "nParticle" ( for example "nParticle 1e3;" ) the solution was done without any problem.
The case file attached.
Best regards
Bijan Darbari
The error:
|  \\    /   O peration     | Version:  dev                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : dev-46d69e1deaed
Exec   : DPMFoam
Date   : Jul 30 2016
Time   : 02:59:11
Host   : "bijan-virtual-machine"
PID    : 9318
Case   : /home/bijan/Desktop/mycase11
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading g
Reading field U
Reading field p
Reading/calculating continuous-phase face flux field phic
Creating turbulence model
Selecting incompressible transport model Newtonian
Creating field alphac
Constructing kinematicCloud kinematicCloud
Constructing particle forces
    Selecting particle force sphereDrag
Constructing cloud functions
    none
Constructing particle injection models
Creating injector: model1
Selecting injection model kinematicLookupTableInjection
    Constructing 2-D injection
    Choosing nParticle to be a fixed value, massTotal variable now does not determine anything.
Selecting dispersion model none
Selecting patch interaction model localInteraction
    Interaction fields will not be written
Selecting stochastic collision model none
Selecting surface film model none
Selecting U integration scheme Euler
Selecting collision model none
Selecting turbulence model type laminar
Starting time loop
Courant Number mean: 0.019975 max: 0.02
Time = 0.0001
Evolving kinematicCloud
Solving 2-D cloud kinematicCloud
Cloud: kinematicCloud injector: model1
    Added 2 new parcels
    Current number of parcels       = 2
    Current mass in system          = 3.14159e-10
    Linear momentum                 = (3.80393e-11 0 0)
   |Linear momentum|                = 3.80393e-11
    Linear kinetic energy           = 3.33858e-06
    model1:
        number of parcels added     = 2
        mass introduced             = 3.14159e-10
    Parcel fate (number, mass)      : patch frontAndBack
      - escape                      = 0, 0
      - stick                       = 0, 0
    Parcel fate (number, mass)      : patch top
      - escape                      = 0, 0
      - stick                       = 0, 0
    Parcel fate (number, mass)      : patch bottom
      - escape                      = 0, 0
      - stick                       = 0, 0
    Parcel fate (number, mass)      : patch inlet
      - escape                      = 0, 0
      - stick                       = 0, 0
    Parcel fate (number, mass)      : patch outlet
      - escape                      = 0, 0
      - stick                       = 0, 0
    Rotational kinetic energy       = 0
PIMPLE: iteration 1
smoothSolver:  Solving for U.airx, Initial residual = 1, Final residual = 1.84189e-09, No Iterations 2
smoothSolver:  Solving for U.airy, Initial residual = 0.0405478, Final residual = 9.99002e-07, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00399794, No Iterations 5
time step continuity errors : sum local = 0.138311, global = -0.000639183, cumulative = -0.000639183
GAMG:  Solving for p, Initial residual = 0.00962409, Final residual = 6.10127e-07, No Iterations 11
time step continuity errors : sum local = 5.79705e-05, global = -1.30051e-06, cumulative = -0.000640483
ExecutionTime = 0.38 s  ClockTime = 0 s
Courant Number mean: 198.274 max: 202140
Time = 0.0002
    Added 2 new parcels
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  ? at ??:?
#4  ? at ??:?
#5  ? at ??:?
#6  ? at ??:?
#7  ? at ??:?
#8  ? at ??:?
#9  ? at ??:?
#10  ? at ??:?
#11  ? at ??:?
#12  ? at ??:?
#13  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14  ? at ??:?
Floating point exception (core dumped)
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      particleProperties;
solution
    active          true;
    coupled         true;
    transient       yes;
    cellValueSourceCorrection on;
    interpolationSchemes
        rho.air         cell;
        U.air           cell;
        mu.air          cell;
    averagingMethod basic;
    integrationSchemes
        U               Euler;
    sourceTerms
        schemes
            U explicit 0.1;
constantProperties
    rho0            10;
    alphaMax        0.05;
subModels
    particleForces
        sphereDrag;
    injectionModels
            % matlab/octave calculation of flow rate
            alpha=0.1
            U=20
            A=0.01^2
            Q=U*A
            d=650e-6
            v=(4/3)*pi*(d/2)^3
            n=1
            rate=alpha*Q/(v*n)
        model1
            type            kinematicLookupTableInjection;
            parcelBasisType fixed;
            inputFile       "parcelInjectionProperties";
            nParticle       1e8;
            parcelsPerSecond 20000;
            massTotal  3.14e7;
            SOI 0;
            duration 150;
            randomise       false;
    dispersionModel none;
    patchInteractionModel localInteraction;
    localInteractionCoeffs
        patches
            frontAndBack
                type rebound;
                e    1;
                mu   0;
           top
                type stick;
                 e    1;
                mu   0;
            bottom
                type stick;
                 e    1;
                mu   0;
            inlet
                type escape;
            outlet
                type escape;
    heatTransferModel none;
    surfaceFilmModel none;
    packingModel none;
    dampingModel none;
    collisionModel  none;
    isotropyModel none;
    stochasticCollisionModel none;
    radiation off;
cloudFunctions
FVschemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(alphaPhic,U.air)    Gauss linearUpwindV unlimited;
    div(((alpha.air*nuEff.air)*dev2(T(grad(U.air))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
    default         linear;
snGradSchemes
    default         corrected;
FVsolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-06;
        relTol          0.01;
        smoother        GaussSeidel;
    pFinal
        solver          GAMG;
        tolerance       1e-06;
        relTol          0;
    "(U|k|omega).*"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-05;
        relTol          0.1;
    "(U|k|omega).*Final"
        $U;
        tolerance       1e-05;
        relTol          0;
PIMPLE
    nOuterCorrectors 1;
    nCorrectors     2;
    momentumPredictor yes;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
relaxationFactors
bijan darbari is offline   Reply With Quote
how to determine the number of particles injected. welch FLUENT 2 January 18, 2024 05:08
DPM Modeling of high Biot Number Particles Bob Stanislawsky FLUENT 1 June 7, 2017 03:15
particles model ati_ros61 FLOW-3D 3 December 6, 2009 17:03
Function to inject particles only once? KK CFX 0 March 4, 2008 16:45
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
