Pipe Flow Simulation
Old   July 27, 2016, 09:46
Default Pipe Flow Simulation
Zhiyi Li
comingdaytime is on a distinguished road
Dear all,
In order to provide the inflow data for LES simulation, I am now conducting a pipe flow simulation.
I am using the ID-DES method with non-uniform boundary conditions and pimpleFoam for the simulation. The diameter of my pipe is 4.25 mm, the length of the pipe is 4 times diameter and cyclic boundary condition. The yplus is smaller than 1 and mostly round 0.2, courant numer smaller than 0.5. According to the pipe diameter, velocity and viscosity, the Reynolds Number should be around 8000-10000, because i set the bulk velocity of 60m/s.
I didn't start the average process. When I check the profile of 0.1s, the profile looks like laminar, there is not turbuence created. Something like that in the attachment. lU_0.0045.jpg Also the velocity profile. U_plot_0.0045.jpg.
But there should be turbulence for me to use the averaging process, otherwise the simulation is not useful for my LES simulation.
Anyone knows if there are some problems with my simulation? Please give me some tips if you have a clue.
Thank you very much
Best regards
Litchy
comingdaytime is offline   Reply With Quote
Old   July 27, 2016, 09:52
Zhiyi Li
The figures I put before is for the time of 0.0045.
You can see the figures for the time of 0.1 here:
Old   July 27, 2016, 11:11
Cedric DUPRAT
cedric_duprat is on a distinguished road
Dear Litchy,
you might find this thread useful to do what you expect.
There are some guidelines for your preprocessing.
http://www.cfd-online.com/Forums/ope...pipe-flow.html
if you have other question(s), let the forum know.
Best regards
Cedric
cedric_duprat is offline   Reply With Quote
Old   July 27, 2016, 11:40
Zhiyi Li
Thank you Cedric, i got some useful recommendations and I'll try them to see if it works
id-des, inflow generation, pipe flow
Wind Tunnel Flow Simulation Mass Flow BC Issue ledelman SU2 4 August 3, 2014 19:38
Y pipe flow simulation iv1985 CFX 2 June 24, 2014 02:35
Blockage in pipe ( using solidwork flow simulation) jchow FloEFD, FloWorks & FloTHERM 1 January 16, 2012 17:03
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
FDTD Simulation of flow through tapered pipe Jim Main CFD Forum 3 December 25, 2006 11:56
