Setting up R
Old   July 25, 2016, 08:09
Default Setting up R
Almond Wong
BakedAlmonds is on a distinguished road
I am trying to run a LRR model simulation. First, I have to tabulate R using the "R" command. But something weird is happening.
In my 0/k file, i have input:
internalField   uniform $turbulentKE;
where turbulentKE is a predefined number earlier.
Then I got his message.
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 21 the word 'uniform'
file: /home/aaaa/OpenFOAM/aaaa/run/ttturbineSitingTryOut/smallDomain_700LRR/0/k.boundaryField.west.value at line 21.
    From function operator>>(Istream&, Scalar&)
    in file lnInclude/Scalar.C at line 93.
FOAM exiting
I got no idea why it is asking for a "scalar" so I followed the instructions and do away with the "uniform" to:
internalField    $turbulentKE;
Then now I am prompt that the keyword "uniform" is not found. Why is this happening??
--> FOAM Warning :
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/openfoam/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/Field.C at line 318
    Reading "/home/aaaa/OpenFOAM/aaaa/run/ttturbineSitingTryOut/smallDomain_700LRR/0/k" from line 9 to line 77
    expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
--> FOAM Warning :
    Reading "/home/aaaa/OpenFOAM/aaaa/run/ttturbineSitingTryOut/smallDomain_700LRR/0/k.boundaryField.east" from line 49 to line 11
BakedAlmonds is offline   Reply With Quote
Old   July 25, 2016, 10:36
Darko Radenkovic
dradenkovic is on a distinguished road
I tried this what you did; it works for me with just this
HTML Code:
tke 0;
internalField   uniform $tke;
Can you try to do k-epsilon simulation, and after that to use R utility? In that way you would avoid this problem.
Regards,
Darko
dradenkovic is offline   Reply With Quote
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Residual level setting of Fluent lhlh ANSYS 2 November 17, 2012 22:35
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Warning 097- AB Siemens 6 November 15, 2004 05:41
