ERROR: Not implemented From function cyclicAMI::coupledFvPatchField<Type>::snGrad()
Old   July 25, 2016, 06:19
Question ERROR: Not implemented From function cyclicAMI::coupledFvPatchField<Type>::snGrad()
mo_na's Avatar
Mona
mo_na is on a distinguished road
Hi guys,
here is a link to the case I am working on: http://www.cfd-online.com/Forums/ope...ixed-body.html
I thought it would be better to open a new thread for the problem I am facing now, because probably its unrelated to my other problem.
I had two mesh parts with AMI1 and AMI2 as cyclicAMI patches both defined as patches in the blockMeshDict. I didn't manage to run snappyHexMesh like this so I used
stitchMesh AMI1 AMI2
After I was able to use snappyHexMesh and added entries for AMI1 and AMI2 for all my files in the 0 folder. I used
    type            cyclicAMI;
    transform       rotational;
    rotationAxis    (0 1 0);
    rotationCentre  (0 0 0);
for everything except pointDisplacement, where I used "slip" (not sure if thats right).
When I try to run the solver (ihDyMFoam) then I get the following error:
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: sixDoFRigidBodyMotion
Selecting sixDoFSolver CrankNicolson
Translational constraint tensor (0 0 0 0 0 0 0 0 0)
Rotational constraint tensor (0 0 0 0 1 0 0 0 0)
PIMPLE: Operating solver in PISO mode
Reading field porosityIndex
Porosity NOT activated
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
--> FOAM FATAL ERROR:
Not implemented
    in file /home/thesis/wilhelm/OpenFOAM/OpenFOAM-3.0.1/src/finiteVolume/lnInclude/coupledFvPatchField.H at line 153.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::coupledFvPatchField<double>::snGrad() const at ??:?
#3  Foam::fv::gaussGrad<double>::correctBoundaryConditions(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) at ??:?
#4  Foam::fv::gaussGrad<double>::calcGrad(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) const at ??:?
#5  Foam::fv::gradScheme<double>::grad(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) const at ??:?
#6  Foam::tmp<Foam::GeometricField<Foam::outerProduct<Foam::Vector<double>, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) at ??:?
#7  Foam::interfaceProperties::calculateK() at ??:?
#8  Foam::interfaceProperties::interfaceProperties(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::IOdictionary const&) at ??:?
#9  Foam::immiscibleIncompressibleTwoPhaseMixture::immiscibleIncompressibleTwoPhaseMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#10  ? at ??:?
#11  __libc_start_main in "/lib64/libc.so.6"
#12  ? at /home/abuild/rpmbuild/BUILD/glibc-2.18/csu/../sysdeps/x86_64/start.S:125
Am I doing something wrong or could this be a bug?
Thanks for your help everyone!
Cheers,
Mona
mo_na is offline   Reply With Quote
Old   July 25, 2016, 10:36
Default solved (more or less)
mo_na's Avatar
Mona
Ok apparently it wasn't right to use stitchMesh in this case. I separated my case in 2 parts now and then used mergeMeshes after snapping in the geometry in one of them (I explained it in the other thread) .
Now I don't get that error message anymore.
[snappyHexMesh] Problem with parallel run of snappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 5 April 15, 2016 05:12
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
