Continuing incompressible results with compressible solver
Old   July 22, 2016, 09:54
Default Continuing incompressible results with compressible solver
Andreas Linkamp
linkamp is on a distinguished road
Hi everyone,
I want to simulate the shedding at a vortex flowmeter. I want to see how the vertices are propagated and if eventually plane waves come into being. This is obviously a compressible case. The problem is, if I simulate this body (with rhoPimpleFoam) initialized with the target velocity (in the whole internal field) of the operating point (say 6 m/s) I get two pressure waves starting from the body because the fluid "runs towards" the upstream wall (high pressure pulse) and "runs away" from the downstream wall (low pressure pulse). These are getting reflected at the walls and totally disturb my solution.
So my idea was to calculate an incompressible solution first, say with pimpleFoam, to obtain an appropriate velocity and pressure field around the body. Afterwards I want to continue with rhoPimpleFoam to take into account compressible effects.
However, I will need a rho field then. Theoretically I can calculate the density by means of pressure and temperature (assuming ideal gas). Can anyone help me how to carry that out practically? Can I do that somehow with foamCalc (havent found rho calculation yet) ? or is there any other possibility?
Thanks in advance
linkamp is offline   Reply With Quote
Evaporation in an Incompressible Lagrangian (LPT) solver? jheide OpenFOAM Programming & Development 7 September 21, 2021 16:36
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 16:44
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 09:23
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM Running, Solving & CFD 17 December 3, 2014 20:41
starting compressible flow from incompressible flow results mihaipruna OpenFOAM Running, Solving & CFD 2 December 3, 2012 11:02
