Problems with decomposePar and mapFields
Old   July 20, 2016, 10:40
Default Problems with decomposePar and mapFields
Hauke Stachel
Fischlurch is on a distinguished road
Hey all,
I have a problem running decomposePar after installing OF 2.3.1 on a Ubuntu 14.04 32-bit machine. Since the same case worked on another (64-bit) PC, I am not sure if it is related to missing/wrong installation or something else.
The case is a interDyMFoam with prior application mapFIelds. The mapping works without troubles, but after applying decomposePar (any number of cores) I get the error:
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.1-262087cdf8db
Exec   : decomposePar -cellDist
Date   : Jul 20 2016
Time   : 10:58:46
Host   : xxx
PID    : 4014
Case   : xxx
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Decomposing mesh region0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod hierarchical
Finished decomposition in 0.43 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
Processor 0
    Number of cells = 113051
    Number of faces shared with processor 1 = 2426
    Number of processor patches = 1
    Number of processor faces = 2426
    Number of boundary faces = 5984
Processor 1
    Number of faces shared with processor 0 = 2426
    Number of faces shared with processor 2 = 8196
    Number of processor patches = 2
    Number of processor faces = 10622
    Number of boundary faces = 15134
Processor 2
    Number of faces shared with processor 1 = 8196
    Number of faces shared with processor 3 = 5102
    Number of processor faces = 13298
    Number of boundary faces = 17024
Processor 3
    Number of cells = 113054
    Number of faces shared with processor 2 = 5102
    Number of processor faces = 5102
    Number of boundary faces = 7992
Number of processor faces = 15724
Max number of cells = 113054 (0.001990238983% above average 113051.75)
Max number of processor patches = 2 (33.33333333% above average 1.5)
Max number of faces between processors = 13298 (69.14271178% above average 7862)
Wrote decomposition to "/home/rechenknecht/Documents/OpenFOAM/currentWork/phase_04/InterDyM_SeaDragon_Run02_w0.71_A0.05/constant/cellDecomposition" for use in manual decomposition.
Wrote decomposition as volScalarField to cellDist for use in postprocessing.
Time = 0
Processor 0: field transfer
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  Uninterpreted:
#3  Foam::List<double>::List(Foam::List<double> const&) at ??:?
#4  Foam::processorFvPatchField<double>::processorFvPatchField(Foam::processorFvPatchField<double> const&, Foam::DimensionedField<double, Foam::volMesh> const&) at ??:?
#5  Foam::processorFvPatchField<double>::clone(Foam::DimensionedField<double, Foam::volMesh> const&) const at ??:?
#6  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::PtrList<Foam::fvPatchField<double> > const&) at ??:?
 at ??:?
 at ??:?
#9  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
 at ??:?
Boundary conditions for k and omega for the new case are defined as non-zero, and the libc.s0.6 is available.
So my question is, has anyone experienced such an error? What does teh error related to processorFvPatchField mean, should be related to the processor internal boundaries, or?
Edit: It appears also in other cases after meshing.
Fischlurch is offline   Reply With Quote
Old   July 24, 2016, 15:36
T.D. is on a distinguished road
what happens if you change the "decompositionMethod" ? is it same error ?
T.D. is offline   Reply With Quote
Old   October 7, 2016, 08:51
Hauke Stachel
yes I checked multiple methods, but then I decided to reinstall ubuntu and everything wokrs fine, cant say where the error was ...
decomposepar, error, mapfields
implementation of mapFields into parallel transient case simpomann OpenFOAM Pre-Processing 4 August 2, 2016 05:41
mapFields : mpirun gives segmentation fault vanihba2000 OpenFOAM Pre-Processing 1 October 13, 2015 13:07
mapfields gives nothing under parallel running. openfoam22x sharonyue OpenFOAM Running, Solving & CFD 0 January 12, 2015 10:02
Question about decomposePar RDanks OpenFOAM Pre-Processing 2 May 20, 2011 10:24
transientSimpleDyMFoam, mapFields and decomposePar pad OpenFOAM Running, Solving & CFD 0 December 3, 2010 06:22
