Viscoelastic Solver
Old   July 20, 2016, 04:09
Default Viscoelastic Solver
A. Min
alimea is on a distinguished road
Hi friends
I've just learnt the openFoam. I solved a special problem with a newtonian fluid(water). Now, I want to solve it with a viscoelastic fluid by Oldroyd-B model. Could you please help me to do it step by step? (you know, I don't know any thing about it!)
Thanks every body
alimea is offline   Reply With Quote
Old   July 24, 2016, 15:42
T.D. is on a distinguished road
You can look to the viscosity models already in OpenFOAM, in:
..your openfoam directory.../src/transportModels/incompressible/viscosityModels
In a shell, you can find them by typing:
Now, based on your needs you can create your new viscosity model similarly as a new library.
If difficult for you, you can also try simply at the Top-level code (directly in the openfoam solver files .H & .C)
Good Luck !
regards,
T.D.
T.D. is offline   Reply With Quote
Old   July 25, 2016, 09:40
A. Min
Thank you my friend
Old   December 25, 2017, 03:59
Default vortex in 3D channel
farhad
bfzah is on a distinguished road
Hello
How can I form a vortex in a square-shaped channel?
Or how can I see vortices?
In all the papers, a vortex pair is seen at the corners of the channel with the Giesekus model.
How can this be modeled with open foam?
what is the properties flow ?
B.C ?
please help me?
my Email: farhadhoseinbor@gmail.com
Telegram id: @bfzah
bfzah is offline   Reply With Quote
Old   November 15, 2019, 10:20
idrees khan
idrees khan is on a distinguished road
Originally Posted by T.D. View Post
Good Luck !
regards,
T.D.
Hi T.D,
kindly i have a confusion i use OpenFoam version 1812 (in this version solver and source code were in the same directory).now i need foam-extend.4.0 but where is the main source file code.(for oldroyd-B model)
idrees khan is offline   Reply With Quote
oldroyd, openfoam, solver control, viscoelasticfluid, viscoelasticfluidfoam
Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam jovani OpenFOAM Running, Solving & CFD 475 January 13, 2023 09:21
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
