Multiple inlets with different temperatures in compressible flow, boundary condition
Old   July 20, 2016, 01:15
Default Multiple inlets with different temperatures in compressible flow, boundary condition
fedvasu is on a distinguished road
I have a very basic question, what should be the outlet boundary condition if I have multiple inlets with different fluid velocity and temperature?
I am currently using something like this
Inlet0
        type             fixedValue;
        value            uniform 1000;
    Inlet1
        type              fixedValue;
        value             uniform 300;
    Inlet2
     	type             fixedValue;
	value            uniform 300;
    outlet
     	type          inletOutlet;
	value         300;
	inletValue    300;
my solver is rhopimplefoam. is that OK?
Any corrections welcome.
fedvasu is offline   Reply With Quote
Old   July 24, 2016, 15:44
T.D. is on a distinguished road
It depends on what you need to do exactly..
regards,
T.D.
T.D. is offline   Reply With Quote
Old   August 4, 2016, 11:13
Originally Posted by T.D. View Post
regards,
T.D.
I just want a simple mixing of two streams which have different velocity and temperature.
(interested in mixing pattern)
I don't much care for the outlet as long as it is consistent.
Old   August 4, 2016, 11:23
you can use "type zeroGradient" for velocity at outlet,
and for pressure:
outlet { type fixedValue; value uniform 0; }
Good Luck
regards,
T.D.
Old   August 4, 2016, 11:37
and for pressure:
Good Luck
regards,
T.D.
Thanks TD,
But does uniform 0 pressure makes sense?
because the pressure is physical pressure isn't it? I have kept outlet as 1 atm, same as internalfield and velocity is as you have mentioned.
But I am not so sure about temperature.
Old   June 12, 2018, 18:39
Originally Posted by fedvasu View Post
Thanks TD,
Old thread of mine, now I know more.
Whenever in doubt use zeroGradient for velocity and other scalars(temeprature, species mass fractions etc) for outlet.
and fixedValue for pressure for the outlet.(typically ambient pressure).
rhopimplefoam, temperature bc
Appropriate pressure boundary condition in incompressible flow lonelywing OpenFOAM Running, Solving & CFD 21 June 6, 2022 10:44
Suitable inlet boundary condition for a compressible flow simulation siw FLUENT 13 October 10, 2018 00:54
Outlet boundary condition for compressible nozzle flows blais.bruno OpenFOAM Running, Solving & CFD 0 July 12, 2016 09:40
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 08:20
Compressible Flow - Boundary Conditions Marc FLUENT 1 July 20, 2007 12:04
