SolidDisplacementFOAM with different Young's Modulus value
Old   July 19, 2016, 19:38
Default SolidDisplacementFOAM with different Young's Modulus value
Rolanzo
Rolanzo is on a distinguished road
I am working on geomechanics coupled with reservoir simulation developed from solidDisplacementFoam, and I came across with a problem with different value of Young's Modulus (E) (see attached picture). Basically, the top and bottom layer has larger value of E than the middle layer (about 100 to 1000 times), and the domain is subjected to 6 tractions on all 6 faces. My question is if there is any special way to set up the simulation specifically for traction boundary or I just have to assign value of E differently on each node then run the simulation normally (I have tried this already and it did not seem to work).
Thank you
Rolanzo is offline   Reply With Quote
Plastic Modulus Tobi OpenFOAM 0 July 10, 2015 08:02
ANSYS Workbench - Young's modulus to stress correlation Martin_D Structural Mechanics 0 December 17, 2014 08:03
I Need Source Code of PLIC method of Youngs Kai Yan Main CFD Forum 6 July 7, 2008 05:41
Looking for D.L. Youngs' paper Wen Long Main CFD Forum 1 March 6, 2002 13:27
How to obtain AWRE tech report (Youngs)? Zi-Wei Chiou Main CFD Forum 2 October 4, 2001 12:09
