Reactions on the biofilm
Old   July 17, 2016, 16:16
Default Reactions on the biofilm
Fidel Vallejo
fvallejog is on a distinguished road
Hi OpenFOAMERS
Would you help me with a tips of C++ plus OpenFOAM????
My problem is:
I created a new Solver based on "scalarTransportFoam": The file ".C" is:
while (simple.loop())
Info<< "Time = " << runTime.timeName() << nl << endl;
while (simple.correctNonOrthogonal())
solve
fvm::ddt(CT)
+ fvm::div(phi, CT)
- fvm::laplacian(DT, CT)
fvOptions(CT)
The solver compile without problems.
But, my model do not finish yet!
I want to put a new set of equations, like this: The difficult part is that the equations is only true in the region where U=0, it means in the surface region named "fixedWalls".
if (U.component(0))=0;
solve
fvm::ddt(CT)
+ fvm::div(phi, CT)
- umax*X/Yp*CT/(Ks+CT)
fvOptions(CT)
Please, I wait any comment.
Fidel
fvallejog is offline   Reply With Quote
mass transfer, openfoam, scalartransportfoam, solvers, superficial reaction
How are chemical reactions stored after parsing? DanielW OpenFOAM Programming & Development 3 June 7, 2018 15:39
Problem with Volumetric Reactions in Fluent Kashif Rashid Fluent UDF and Scheme Programming 2 December 28, 2017 01:36
Need Clarification regarding Volumetric Reactions in Fluent Kashif Rashid Fluent UDF and Scheme Programming 0 October 3, 2014 11:59
inconsistency in the chemical reactions in Reacting Foam? lfgmarc OpenFOAM Running, Solving & CFD 1 October 10, 2011 12:11
porous medium and reactions Valeria FLUENT 1 July 10, 2009 04:58
