July 13, 2016, 17:51 |
Recommended Boundary Conditions?
Lori
Rep Power: 11 |
Hello!
So I am running a case using a solver that I customized, and I have more of general question for those that may understand more about stable boundary condition implementations. So, in my simulation I am looking at a channel that is under an applied hydraulic pressure, and I know the incoming velocity. Except I know that it is not a good idea to specify fixed value BCs for velocity and pressure at the inlet. So then I wanted to set the pressure at the outlet, but I also realized this is unstable, as the only value of pressure you should fix at an outlet is static pressure. And I have no idea what the velocity would be at the outlet, as water is permeating into the channel along its length. So, any recommendations on how to specify the BCs? Thank you so much in advance. |
boundary condition, openfoam, pressure, velocity |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 10:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
