Specify mass flow rate for periodic boundary conditions in channel flow
Old   July 11, 2016, 17:39
Default Specify mass flow rate for periodic boundary conditions in channel flow
Dantong Shi
lion1990 is on a distinguished road
Hi, everyone.
I am a beginner of OpenFOAM, and I am simulating a 3D laminar incompressible pipe flow with OpenFOAM. I need to make periodic boundary conditions for inlet and outlet. I use fluent before and I can make periodic boundary conditions and specify either a mass flow rate or a constant pressure drop. In my case, I need to specify the mass flow rate of the inlet/outlet surfaces. I am not sure how to specify a certain mass flow rate for inlet/outlet surfaces since the velocity profile in inlet and outlet keep changing during simulation but the mass flow rate is constant.
I might use cyclic boundary condition to solve the problem. But still I don't know how to set the mass flow rate. Also, I am not sure how to set the pressure boundary condition since there will be a constant pressure drop after each periodic, but this pressure drop is not given and can only be calculated through the given mass flow rate during simulation.
Any ideas on that?
Thank you very much for your help!
lion1990 is offline   Reply With Quote
Old   July 9, 2018, 18:46
behzad Ghasemi
behzad-cfd is on a distinguished road
I know this is an old topic but could you figure out how to do this?
I'm dealing exactly with same problem.
behzad-cfd is offline   Reply With Quote
cyclic bc, mass flow rate, openfoam
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Mass flow rate boundary condition for continuity equation for oscillating flow p07ip705 Main CFD Forum 0 February 28, 2013 02:33
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
