SGS stress tensor B
Old   July 10, 2016, 17:12
Default SGS stress tensor B
Ehsan Asgari
syavash is on a distinguished road
How can I incorporate SGS stress tensor in solver pimpleFoam?!
I have constructed "B" in createField.H as follows:
volSymmTensorField B
    IOobject
        "B",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    mesh,
           dimensionedSymmTensor
           "B",
           dimPressure,
           symmTensor::zero
In pimpleFoam.c, under turbulence->correct(); in the main time loop, I have added:
B = turbulence->B();
when I compile the code, I get the following error:
MypimpleFoam.C: In function ‘int main(int, char**)’:
MypimpleFoam.C:90:32: error: ‘class Foam::incompressible::turbulenceModel’ has no member named ‘B’
I have checked calss turbulenceModel and B is not defined there.
I think B is defined in LESModel.H but when I try to include this file I get compilation errors, indicating that the file cannot be found.
Please help me to solve this problem.
Thanks,
Syavash
PS: I am using OF version 2.3.1
syavash is offline   Reply With Quote
Old   February 10, 2018, 16:26
beatlejuice is on a distinguished road
Dear syavash,
could you please tell me what the SGS stress tensor B is ... or how it is defined?
This would help me a lot since I have to deal with it when using WALE LES model.
Thank you very much in advance!
cheers
beatlejuice is offline   Reply With Quote
Old   February 10, 2018, 16:46
Ehsan Asgari
Originally Posted by beatlejuice View Post
Dear syavash,
cheers
It is the sub-grid scale stress tensor usually defined in literature by tau_ij. It is often placed in the right hand side of momentum equation, undergoing divergence operator. I am sure you will find it in the common turbulence text books such as Pope or Sagaut.
Best regards,
Syavash
Old   February 12, 2018, 13:04
Ahh I see ... the term "B" has unsettled me.
Thank you very much syavash for your fast response!
Old   December 9, 2018, 15:13
Not applicable
kagen816 is on a distinguished road
Originally Posted by syavash View Post
Best regards,
Syavash
Hi Syavash,
I saw the B in GenSGSstress but it does not say how to get this value. The subgrid model can get the Vsgs but how to get B. What's more, in the codes devReff() seems to be Subgrid stress and B is tau_kk? I am very confused.
kagen816 is offline   Reply With Quote
Old   March 22, 2019, 05:51
Manaf Muhammed
manafaero is on a distinguished road
dear sir
do you find an answer that how B and Reff is related in LES. Please help
manafaero is offline   Reply With Quote
Old   March 25, 2019, 10:44
Ehsan Asgari
Originally Posted by kagen816 View Post
Hi Syavash,
Hi kagen,
It might be a little late, but you can find more details in the LESpimpleFoam that I had previously shared out on github:
HTML Code:
https://github.com/syavash20/TurbLab/tree/master/LESpimpleFoam
Best Regards,
Syavash
Old   March 25, 2019, 10:53
Manaf Muhammed
Thankyou very much for your help sir
But can you tell me where exactly or how B is used to solve the equations. I can see Reff is used as a part of U equation but where is B used.
Old   March 25, 2019, 10:58
Ehsan Asgari
B itself is an auxiliary quantity and is not included in primary momentum equations.
Best Regards,
Syavash
Old   March 26, 2019, 05:20
Manaf Muhammed
sir,
As you know the smagorinsky constant Cs in OpenFOAM is defined as a function of Ce and Ck. But when i do the simulation for various combinations of Ck and Ce, that gives the same Cs, I am getting different results. So could you please tell me where else Ck and Ce is used other than in smagorinsky model. My problem is incompressible LES with standard smagorinsky model and vandriest delta.
Please help
Thanking you
Old   March 26, 2019, 06:01
Ehsan Asgari
sir,
Please help
Thanking you
Unfortunately I lack the experience of working with standard Smagorinsky model. However by looking at the source code I see that both ce and ck should be read from dictionary of LESproperties, something like the following should work:
SmagorinskyCoeffs
      filter    simple;
      ck        0.094;
      ce        1.048;
Best Regards,
Syavash
Old   March 26, 2019, 06:06
Manaf Muhammed
dear sir
I think Ck is read from LESproperties and Ce is read from GenEddyvisc.C file. But i would like to know that if Ck and Ce is used anywhere else in incompressible LES with standard smagorinsky model when using a pisoFoam solver (openFOAM2.4x).
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" Jeremie84 ANSYS Meshing & Geometry 70 October 25, 2017 17:03
Reg. LES in OpenFOAM ganeshv OpenFOAM Running, Solving & CFD 39 February 26, 2014 21:07
How the trace term of SGS stress tensor implemented in Openfoam star shower OpenFOAM Running, Solving & CFD 0 March 3, 2012 09:56
shear stress scalar definitions? Novak Elliott CFX 0 April 6, 2003 02:45
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 08:43
