cyclone
Old   July 8, 2016, 08:26
Default cyclone
ali
ebtedaei is on a distinguished road
Dear All,
I want to simulate industrial cyclone separators by MPPICFoam too. For that, I draw a cyclone configuration in SolidWork and producted a STL file, Now I should product grids (meshes) by editing blockMeshDict and then snappyHexMesh...
1- How should I change the blockMeshDict file (vertices, blocks, edges, boundary...) of OpenFoam example and then snappyHexMesh?
2- Should I change the dimensions of the industrial cyclone in OpenFoam?
please help me.
Thanks
ebtedaei is offline   Reply With Quote
Old   August 11, 2023, 08:22
Arrow reply
desimuser1
Desimuser1 is on a distinguished road
1. blockMeshDict boundary must cover your entire cyclone, you can reduce the number of cells per rows for more fine mesh
(checkout motorBike case to learn snappyHexMesh)
blockMesh | tee log.blockmesh
snappyHexMesh -overwrite | tee log.snappyHexMesh
checkMesh | tee log.checkMesh
2. usually dimensions are taken in meters, so scale up/down if you want to change
for eg. if you have dimensioned in mm then scale factor is 0.001 (1m = 1000mm)
hope it helps
Desimuser1 is offline   Reply With Quote
Ideas about Gas - Solid Cyclone Separator Simulations ardismo FLUENT 4 April 6, 2016 09:04
Particle separation in an axial cyclone Cloudseeker CFX 3 August 19, 2014 21:13
Steam-Water Vertical Cyclone Separator Munggang FLUENT 3 April 29, 2014 14:38
requiring solution for heat transfer from gas to solid particle in cyclone suvai79 FLUENT 0 September 1, 2012 06:48
Modelling Industrial cyclone behaviour Günther Hasse Main CFD Forum 3 October 12, 1999 20:34
