FATAL ERROR: Max number of iterations exceeded
Old   July 5, 2016, 16:55
Default FATAL ERROR: Max number of iterations exceeded
Henry
hbrist7 is on a distinguished road
I've been having a lot of trouble tracing the source of this error. I know it happens in the thermoI.H file, but I can't trace what is calling that, or figure out any reason why this is happening.
The case i am running is a simple wedge (meshed with snappy hex mesh) inside a blockmesh region using rhoCentral foam.
any help would be really appreciated
this is the error log file
|  \\    /   O peration     | Version:  3.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 3.0.1-119cac7e8750
Exec   : rhoCentralFoam -parallel
Date   : Jul 01 2016
Time   : 12:54:38
Host   : "cfd01"
PID    : 30359
Case   : /----/wedge15maxIterError
nProcs : 36
Slaves :
35
"cfd01.30360"
"cfd01.30361"
"cfd01.30362"
"cfd01.30363"
"cfd01.30364"
"cfd01.30365"
"cfd01.30366"
"cfd01.30367"
"cfd01.30368"
"cfd01.30369"
"cfd01.30370"
"cfd02.26571"
"cfd02.26572"
"cfd02.26573"
"cfd02.26574"
"cfd02.26575"
"cfd02.26576"
"cfd02.26577"
"cfd02.26578"
"cfd02.26579"
"cfd02.26580"
"cfd02.26581"
"cfd02.26582"
"cfd03.29133"
"cfd03.29134"
"cfd03.29135"
"cfd03.29136"
"cfd03.29137"
"cfd03.29138"
"cfd03.29139"
"cfd03.29140"
"cfd03.29141"
"cfd03.29142"
"cfd03.29143"
"cfd03.29144"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Reading field U
Creating turbulence model
Selecting turbulence model type laminar
fluxScheme: Kurganov
Starting time loop
Mean and max Courant Numbers = 0.00521015 0.119072
deltaT = 2.4e-06
Time = 2.4e-06
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for Ux, Initial residual = 0.999285, Final residual = 0.00389594, No Iterations 5
smoothSolver:  Solving for Uy, Initial residual = 0.999999, Final residual = 8.69665e-17, No Iterations 5
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 8.81879e-17, No Iterations 5
diagonal:  Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for e, Initial residual = 1.46977e-11, Final residual = 1.46977e-11, No Iterations 0
ExecutionTime = 0.68 s  ClockTime = 1 s
Mean and max Courant Numbers = 0.00625242 0.142579
deltaT = 2.88e-06
Time = 5.28e-06
smoothSolver:  Solving for Ux, Initial residual = 6.23273e-10, Final residual = 6.23273e-10, No Iterations 0
smoothSolver:  Solving for Uy, Initial residual = 1.24042e-05, Final residual = 6.5351e-18, No Iterations 5
smoothSolver:  Solving for Uz, Initial residual = 0.00028774, Final residual = 4.85118e-17, No Iterations 5
smoothSolver:  Solving for e, Initial residual = 5.7298e-12, Final residual = 5.7298e-12, No Iterations 0
[0] [1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Maximum number of iterations exceeded
[1]
[1]     From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>]
[1]     in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66.
[1]
FOAM parallel run aborting
[1]
[2]
[2]
[2] --> FOAM FATAL ERROR: [3]
[3]
[3] --> FOAM FATAL ERROR:
[3] Maximum number of iterations exceeded
[3]
[3]     From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>]
[3]     in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66[7]
[7]
[7] --> FOAM FATAL ERROR:
[7] Maximum number of iterations exceeded
[7]
for reference, my P/T/U files are here:
p:
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 18822.7;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 18822.7;
    outlet
        type            zeroGradient;
    airplane
	type		zeroGradient;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    symmetry
	type		symmetryPlane;
    left
	type 		zeroGradient;
    defaultFaces
        type            zeroGradient;
T:
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 216.65;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 216.65;
    outlet
        type            zeroGradient;
    airplane
	type		zeroGradient;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    left
	type		zeroGradient;
    symmetry
	type		symmetryPlane;
    defaultFaces
        type            zeroGradient;
U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (400 0 0); //(246.933 0 0);
boundaryField
    inlet
        type		fixedValue;
        value           uniform (400 0 0); //(246.933 0 0);
    outlet
        type            zeroGradient;
    airplane
	type		slip;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    left
	type		zeroGradient;
    symmetry
	type		symmetryPlane;
    defaultFaces
        type            zeroGradient;
hbrist7 is offline   Reply With Quote
Old   July 6, 2016, 17:02
Henry
Also, I changed the boundary conditions to supersonicFreestream and waveTransmissive in hopes that that would help, but i am getting the same problem.
I have my entire post-run case directory on dropbox, with the error located in the log.rho file
https://www.dropbox.com/sh/7fvzzazmx...liXvZj0ga?dl=0
Does anyone have any ideas what the problem is?
Old   March 15, 2019, 09:15
Hao Li
haolee0928 is on a distinguished road
Date   : Jul 01 2016
Time   : 12:54:38
Host   : "cfd01"
PID    : 30359
nProcs : 36
Slaves :
35
"cfd01.30360"
"cfd01.30361"
"cfd01.30362"
"cfd01.30363"
"cfd01.30364"
"cfd01.30365"
"cfd01.30366"
"cfd01.30367"
"cfd01.30368"
"cfd01.30369"
"cfd01.30370"
"cfd02.26571"
"cfd02.26572"
"cfd02.26573"
"cfd02.26574"
"cfd02.26575"
"cfd02.26576"
"cfd02.26577"
"cfd02.26578"
"cfd02.26579"
"cfd02.26580"
"cfd02.26581"
"cfd02.26582"
"cfd03.29133"
"cfd03.29134"
"cfd03.29135"
"cfd03.29136"
"cfd03.29137"
"cfd03.29138"
"cfd03.29139"
"cfd03.29140"
"cfd03.29141"
"cfd03.29142"
"cfd03.29143"
"cfd03.29144"
    floatTransfer      : 0
    nProcsSimpleSum    : 0
Create time
    type            hePsiThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
Reading field U
Starting time loop
deltaT = 2.4e-06
Time = 2.4e-06
deltaT = 2.88e-06
Time = 5.28e-06
[0] [1]
[1]
[1]
[1]
[1]
[2]
[2]
[3]
[3]
[7]
[7]
p:
boundaryField
    inlet
        type            fixedValue;
    outlet
        type            zeroGradient;
    airplane
	type		zeroGradient;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    symmetry
	type		symmetryPlane;
    left
	type 		zeroGradient;
    defaultFaces
        type            zeroGradient;
T:
boundaryField
    inlet
        type            fixedValue;
    outlet
        type            zeroGradient;
    airplane
	type		zeroGradient;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    left
	type		zeroGradient;
    symmetry
	type		symmetryPlane;
    defaultFaces
        type            zeroGradient;
U:
boundaryField
    inlet
        type		fixedValue;
    outlet
        type            zeroGradient;
    airplane
	type		slip;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    left
	type		zeroGradient;
    symmetry
	type		symmetryPlane;
    defaultFaces
        type            zeroGradient;
Hi, I met the nearly same trouble. Could you tell me how to fix it. Just a roadmap is ok
haolee0928 is offline   Reply With Quote
Old   May 13, 2022, 15:55
Fuad Hasibul Hasan
fuad is on a distinguished road
Have you solved this issue? I'm facing a similar error. I've been working on this error for more than a week but could not solve this yet. Please share if you did.
In my observation after trying a lot of things is that they are may be a unit problem of the initial and boundary conditions and thermophysical properties. The tutorial cases use the normalized parameters and as soon as I change them to S.I. units like here it causes this error.
fuad is offline   Reply With Quote
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 03:42
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
