Separation buble in airfoil simulation
Old   July 4, 2016, 11:12
Default Separation buble in airfoil simulation
jck
jck is on a distinguished road
i have to calculate and analyze the flow around a NACA 4412 airfoil. The cp plot is similar to experimental data of the NASA:
http://turbmodels.larc.nasa.gov/naca4412sep_val.html
I use the kOmegaSST model with wallfunctions and a y+ of around 100. The checkMesh command gives the result ok.
The difference between my results and the plot of the nasa is a "step" in my cp progress (cp15deg.jpg)
It looks like a separation bubble from a laminar to turbulent flow. But the flow should be turbulent everywhere. Does anyone heard something about transition problems with wall functions?
Thanks in advance
Claus
jck is offline   Reply With Quote
Airfoil simulation - Divergence of the results - Mesh or geometry problem ? Pol.P FLUENT 9 March 7, 2022 18:21
pressure plot mild oscillations in 2D airfoil simulation with simplefoam(parallel) mugabe2204 OpenFOAM Running, Solving & CFD 2 March 19, 2015 21:44
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 11:27
Automatic Simulation of 2D Airfoil Section at Different Angles of Attack Hybrid ANSYS 3 May 10, 2012 23:26
[CFX] Simulation of Flow Separation in a rectangular diffuser - Convergence Problem anon_b CFX 11 May 6, 2012 21:16
