time step restriction for implicit icoFoam??? |
June 29, 2016, 03:29 |
Rep Power: 11 |
Dear Foamers,
during my research I noticed, that there is a time step restriction for the momentum predictor. I tested different meshsizes and timesteps in the cavity case of icoFoam found then following restrictions: 1.) Co = u_wall*dt/dx < 1 (as usuall) 2.) nu*dt/dx² < 0.25 The last restriction seems strange, because icoFoam uses an implicit scheme. Why do we have this restriction, where van-Neumann-stability-analysis predicts unconditional stabilyty for the implicit diffusive term in momentum equation? Do you observe the same restriction? Do you know how to overcome this problem? Thanks for your help, K.C. |
July 6, 2016, 03:51 |
Rep Power: 11 |
Does anybody have an idea?
By the way an increase in corrector loops seems to soften the last restriction, but nevertheless a reson for this restriction is missing. |
July 12, 2016, 04:06 |
Rep Power: 11 |
Please,
could anybody just confirm my observation and try the icoFoam-cavity case with nu*dt/dx² > 0.25? Every literature tells me that implicit treatment of viscous stresses should avoid this time step restriction, but my icoFoam has this restriction. Thanks to you. |
August 1, 2016, 10:39 |
Rep Power: 11 |
This restriction is a huge problem for me and I dont understand, that every literature (e.g. Ferzinger) writes that solving the momentum predictor should be unconditional stable.
February 23, 2017, 18:19 |
same problem
longhui zhang
Dear K.C.
Did you find the answer to this problem? I tested with icoFoam and found the same restriction on time step. Could you please tell me what produces this restriction if you already got the answer? Thank you very much! Zhang |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
