June 28, 2016, 09:25 |
Oxyfuel simulation with 1Eq model
Bah.Mah
Rep Power: 10 |
Dear all
I´m trying to simulate with pimplefoam a case of Oxyfuel burner and the LES model is 1EddyEq model. I have just started the simulation but I got this error which I could not understand : ``Create time Create mesh for time = 22 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type LESModel Selecting LES turbulence model oneEqEddyEKT Selecting LES delta type vanDriest Selecting LES delta type cubeRootVol oneEqEddyEKTCoeffs { ce 1.048; ck 0.05; } No finite volume options present PIMPLE: max iterations = 10 field U : relTol 0, tolerance 1e-06 field p : relTol 0, tolerance 1e-06 field k : relTol 0, tolerance 1e-06 Starting time loop End`` => The red line is my prblem and I don´t thinks it has a relation with the fvOptions file in the syteme folder Any respond will be appreciated. |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Which model is accurate for cooling water jacket simulation? | manupp | STAR-CCM+ | 1 | May 22, 2015 01:02 |
Fan Curve Model with CHT simulation | mariconeagles96 | CFX | 5 | April 22, 2015 02:31 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
LES simulation with Smagorinsky2 model | Zuixy | OpenFOAM Running, Solving & CFD | 3 | October 20, 2011 07:17 |
