Boundary Condition Values
Old   June 27, 2016, 14:22
Default Boundary Condition Values
Kevin Cole
kodexys is on a distinguished road
Hello everyone, could someone please explain to me what the values in boundary patches specify? I'm trying to run simulations with roughness and I'm not sure what OpenFOAM is doing when I set something like
type     nutkRoughWallFunction
Ks        uniform 0;
Cs        uniform 0.5;
value     uniform 0;
kodexys is offline   Reply With Quote
Old   June 27, 2016, 23:29
Mahdi Hosseinali
anishtain4 is on a distinguished road
if you look for the file in the source code you'll find this:
Description
This boundary condition provides a turbulent kinematic viscosity condition
when using wall functions for rough walls, based on turbulence kinetic
energy. The condition manipulates the E parameter to account for roughness
effects.
Parameter ranges
- roughness height = sand-grain roughness (0 for smooth walls)
- roughness constant = 0.5-1.0
\heading Patch usage
\table
Property | Description | Required | Default value
Ks | sand-grain roughness height | yes |
Cs | roughness constant | yes |
\endtable
Example of the boundary condition specification:
\verbatim
myPatch
type nutkRoughWallFunction;
Ks uniform 0;
Cs uniform 0.5;
\endverbatim
anishtain4 is offline   Reply With Quote
Old   June 28, 2016, 10:49
Kevin Cole
Thanks Mahdi for your reply.
However, I don't see how it answers my question of what the values in boundary patches specify.
boundary, boundary condition, rough, values
several fields modified by single boundary condition schröder OpenFOAM Programming & Development 3 April 21, 2015 06:09
Implement a new boundary condition and writes out the values kmefun OpenFOAM Running, Solving & CFD 0 September 19, 2014 13:03
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
