compressible flow, rhoSimpleFoam, boundary conditions
Old   June 26, 2016, 15:27
Default compressible flow, rhoSimpleFoam, boundary conditions
Lefteris
Aeronautics El. K. is on a distinguished road
Hi all.
I'm trying to solve a compressible flow with rhoSimpleFoam but I can't get it to converge. I believe it is a boundary conditions issue as simpleFoam does run ok on the same mesh (for lower velocity, incompressible cases).
The topology consists of one inflow and two outflows (please see the attached image to get the idea). My problem is that I cannot find the right set of boundary conditions for the patch in coloured in red on the image.
All variables are known at the inlet.
I'm not sure if this makes any difference but that's the thermophysical properties I use:
type hePsiThermo;
mixture pureMixture;
transport sutherland;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleInternalEnergy;
Can someone suggest what set of boundary conditions could work with rhoSimpleFoam?
Thanks a lot!
ps
I use OF 3.0.1 but I could also use OF 2.3.1.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
boundary condition, compressible flow, rhosimplefoam
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Boundary conditions at inlet/outlet of a pipe with compressible flow nicola_78 Main CFD Forum 10 November 19, 2015 12:20
Radiation interface hinca CFX 15 January 26, 2014 18:11
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
