rhoCentralFoam parallel running
Old   June 24, 2016, 14:51
Default rhoCentralFoam parallel running
Henry
hbrist7 is on a distinguished road
Hey guys,
I've been working to set up rhoCentralFoam in parallel by modifying the wedge tutorial. I'm using snappyHexMesh to mesh around an stl file to recreate the wedge shape, and run the entire case in a parallel configuration. When I run the series case, it runs perfectly, but in parallel I keep getting a floating point exception which I can't make heads or tails of. I'm pretty confident after checking the mesh with both checkMesh and paraView that the mesh has been set up correctly. This seems like something to do with the solver itself. I've attached to log file with the error.
wtest - log.rhoCentralFoam.docx
Thanks,
Henry
hbrist7 is offline   Reply With Quote
error, floatingpoint, help needed, parallel, rhocentralfoam
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 10 February 22, 2017 22:33
running OpenFoam in parallel vishwa OpenFOAM Running, Solving & CFD 22 August 2, 2015 09:53
OpenFoam Parallel running shipman OpenFOAM Running, Solving & CFD 3 August 17, 2013 11:50
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
