Values and Wall Functions
Old   June 23, 2016, 13:24
Default Values and Wall Functions
Kevin Cole
kodexys is on a distinguished road
This is from the OpenFOAM C++ Source Code guide, which I tried to implement in my 0/nut
<patchName>
    type            nutUSpaldingWallFunction;
When I run the code, OpenFOAM complains that there is no specified value, despite the lack of it in the source guide.
My question is if there is a workaround for leaving out the value and having it work. If not, I would like to know what suitable values would be for a rough wall simulation.
Any help would be greatly appreciated.
kodexys is offline   Reply With Quote
Old   June 24, 2016, 05:04
Zbynek is on a distinguished road
You need to set a value for the boundary patch as well. Even though the quantity in question is going to be calculated using a wall function, you set its initial value. So it would be something like this:
<patchName>
    value          0;
Simply check settings in one of the many tutorials that come with OF installation!
Zbynek is offline   Reply With Quote
Old   June 24, 2016, 16:14
Kevin Cole
Thanks for the reply Zbynek! I tried that out and it indeed worked.
Do you by any chance know what the F3 coefficient in the kw SST model does?
Old   June 29, 2016, 05:15
Hi Kevin,
The answer on your question is hidden in the header file of the k-omega SST model.
Description
    Implementation of the k-omega-SST turbulence model for incompressible
    flows.
    Turbulence model described in:
    \verbatim
        Menter, F., Esch, T.,
        "Elements of Industrial Heat Transfer Prediction",
        16th Brazilian Congress of Mechanical Engineering (COBEM),
        Nov. 2001.
    \endverbatim
    with the addition of the optional F3 term for rough walls from
    \verbatim
        Hellsten, A.
        "Some Improvements in Menter’s k-omega-SST turbulence model"
        29th AIAA Fluid Dynamics Conference,
        AIAA-98-2554,
        June 1998.
    \endverbatim
rough, values, wall function
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 12:55
Rough Wall Functions Troubleshooting: (OF 1.6.x, incompressible) PainInTheMesh OpenFOAM Running, Solving & CFD 0 October 15, 2013 23:09
Modify, G_k,k and epsilon values on wall functions Javier Larrondo FLUENT 0 September 15, 2008 22:34
Correct values for constants k E in wall functions jaswi OpenFOAM Running, Solving & CFD 0 February 21, 2008 12:33
