How to put an already-obtained velocity distribution as initial condition???
Old   June 23, 2016, 13:19
Default How to put an already-obtained velocity distribution as initial condition???
Sheikh Ahmed
sahmed is on a distinguished road
Hello Foamers
I need your suggestion regarding a very interesting and useful topic. Suppose I got a fully-developed velocity profile from a pipe flow solution (U Vs. Z) and I want to implement it to another problem as an initial velocity field. This might save some of the computational time since the solver is already dealing with a good solution.
Did anyone use this type of condition in any of your simulations?? ANY type of suggestion is highly appreciated.
sahmed is offline   Reply With Quote
Old   June 23, 2016, 16:44
Sheikh Ahmed
Anybody please give me some hints from your experience how to add my own initial conditions to a problem, say an initial temperature profile or an initial velocity profile
Old   June 23, 2016, 17:06
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
User Guide, chapter 2.1.5.3. In fact whole section 2.1.5 could be useful - http://cfd.direct/openfoam/user-guid...#x5-170002.1.5.
alexeym is offline   Reply With Quote
Old   June 23, 2016, 17:20
Sheikh Ahmed
Thanks Alexey. I was thinking of using somehow the setFields utility to specify a user-defined initial velocity of temperature profile. This might be the easiest option if I can do that.
Not necessarily that I have to merge the older one with the new one as you mentioned. Suppose that I have any profile and I want to use it as my initial condition instead of a fixed value.
PLEASE help me if you have any idea.
Old   June 23, 2016, 17:36
Alexey Matveichev
Well, you can use setFields, you can use codeStream as internalField (if you know OpenFOAM's C++), you can use so called funkySetFields (according to forum it can be used for the case you have described, yet I have never used it myself). Below is an example of codeStream as internalField for velocity:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   #codeStream
    codeInclude
        #include "fvCFD.H"
        #include "vectorField.H"
    codeOptions
        -I$(LIB_SRC)/finiteVolume/lnInclude \
        -I$(LIB_SRC)/meshTools/lnInclude
    code
        const IOdictionary& d = static_cast<const IOdictionary&>(dict);
        const fvMesh& mesh = refCast<const fvMesh>(d.db());
        vectorField U(mesh.nCells());
        const vector C = vector(0.05, 0.05, 0.005);
        forAll(U, i)
            const vector& Ci = mesh.C()[i];
            const vector R = Ci - C;
            U[i] = R ^ Ci;
        U.writeEntry("", os);
[your boundary conditions]
Since your description of the problem is rather vague, there are plenty of possibilities. "Any profile" proposes random solution.
Old   September 5, 2019, 13:18
Alejandro
ancolli is on a distinguished road
FoamFile
    version     2.0;
    format      ascii;
    object      U;
    codeInclude
        #include "fvCFD.H"
    codeOptions
    code
        forAll(U, i)
            U[i] = R ^ Ci;
I am having the following Error in OpenFOAM-dev
error: ‘Foam::vectorField {aka class Foam::Field<Foam::Vector<double> >}’ has no member named ‘writeEntry’
/opt/openfoam-dev/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/codeStreamTemplate.o' failed
make: *** [Make/linux64GccDPInt32Opt/codeStreamTemplate.o] Error 1
however, in OpenFOAM-6 is working well.
ancolli is offline   Reply With Quote
Old   September 6, 2019, 08:16
Carlo_P
Carlo_P is on a distinguished road
A very simplem method can be copy and paste the value in the oldSim/U to the nuew 0/U.
If the mesh is different, you can easily apply a mesh conversion
Carlo_P is offline   Reply With Quote
fully developed flow, initial velocity field, velocity profile
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
