How to add a Boundary condition???
Old   June 16, 2016, 20:55
Question How to add a Boundary condition???
Lee
lxwd is on a distinguished road
Dear all,
I am now trying to add one existing boundary condition, atmBoundaryLayerInletVelocity, from openfoam 3.0.1 to foam-extend 3.1. I follow the tutorial found from foamwiki, as shown below.
HTML Code:
https://openfoamwiki.net/index.php/HowTo_Adding_a_new_boundary_condition
Choose a boundary condition that is close to the one you want - we'll call it originalFvPatchField.
Copy the directory contents to anywhere (say run/myCode).
Rename all the copied files to a new name (say customFvPatchField).
for i in `ls`; do mv $i `echo $i|sed s/originalFvPatchField/customFvPatchField/g`;done
Search & replace all text in all the new files old name for new name (originalFvPatchField replaced with customFvPatchField)
 for i in `ls`; do sed -i s/originalFvPatchField/customFvPatchField/g $i;done
Modify the code to suit your needs.
Create the directory structure: myCode/Make, and create files and options in it.
Put the relevant info into files:
Search for originalFvPatchField in finiteVolume/Make/files.
Copy the relevant entry (entries) into your myCode/Make/files
Rename the entries as necessary - rename it with your customFvPatchField naming (if there's an s on the end, keep it there).
Tell it what the new library name will be. Use $(FOAM_USER_LIBBIN) instead of $(FOAM_LIBBIN), and add lib to the front of the new name. It should look something like: LIB = $(FOAM_USER_LIBBIN)/libcustomPatchField
The options file should have EXE_INC (for any includes such as -I$(LIB_SRC)/finiteVolume/lnInclude for finiteVolume) and LIB_LIBS (for included libraries, such as -lfiniteVolume for finiteVolume). Look at other LIB_LIBS for examples.
$wmake libso
Add whatever new dictionary entries are needed to your initial conditions files, such as 0/U and 0/P files.
Add libs ( "libcustomFvPatchField.so" "libOpenFOAM.so" ) to controlDict
It should run now.
However, when I type "wmake libso" in the terminal, it gives me the error shown below.
make: *** No rule to make target `fields/fvPatchFields/derived/atmBoundaryLayer/atmBoundaryLayer.dep', needed by `Make/linux64GccDPOpt/dependencies'.  Stop.
Attached codes is in my "files" and "options" under "Make" directory.
fvPatchFields = fields/fvPatchFields
derivedFvPatchFields = $(fvPatchFields)/derived
$(derivedFvPatchFields)/atmBoundaryLayerInletVelocity/atmBoundaryLayerInletVelocityFvPatchVectorField.C
LIB = $(FOAM_USER_LIBBIN)/libatmBoundaryLayerInletVelocityFvPatchVectorField
EXE_INC = \
LIB_LIBS =
Any help is greatly appreciated!!!
Best Regards,
Lee
lxwd is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
several fields modified by single boundary condition schröder OpenFOAM Programming & Development 3 April 21, 2015 06:09
How to add a boundary condition with journal cmds Cyril FLUENT 0 May 22, 2006 12:16
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
