bouyantBoussinesqSimpleFoam continuity error
Old   June 15, 2016, 12:29
Default bouyantBoussinesqSimpleFoam continuity error
xin
xinsui178 is on a distinguished road
Hey guys
I am very new to openFoam. When i am dealing with a heat transfer problem by using bouyantBoussinesqSimpleFoam solver, I have been facing this continuity error:
Time = 9
DILUPBiCG: Solving for Ux, Initial residual = 0.0885082, Final residual = 0.000499796, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.0950988, Final residual = 0.000374206, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.0804916, Final residual = 0.000396186, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 0.00228062, Final residual = 0.000160895, No Iterations 1
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3] Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 3.57479
Specified mass inflow : 0.0281187
Specified mass outflow : 0
Adjustable mass outflow : 2.27509e-19
[3]
[3]
[3] From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
[3] in file cfdTools/general/adjustPhi/adjustPhi.C at line 114.
[3]
FOAM parallel run exiting
I tried the potentialFoam but again I had continuity error as well.
GAMG: Solving for Phi, Initial residual = 5.91752e-07, Final residual = 5.91752e-07, No Iterations 0
Continuity error = 0.0634313
Interpolated velocity error = 0.00215528
ExecutionTime = 4 s ClockTime = 5 s
Can anyone who solved the kind of problem give me any clue about it? I had two inlet with two different temperatures and velocities and my setups are as below:
U:
boundaryField
inlet1
type fixedValue;
value uniform (46 0 0);
inlet2
type fixedValue;
value uniform (0 1.89 0);
outlet
type zeroGradient;
symmetric1
type slip;
symmetric2
type slip;
blade
type fixedValue;
value uniform (0 0 0);
P:
blade
type zeroGradient;
outlet
type fixedValue;
value uniform 0; //pascals divided by the density (equiv 1 bar)
inlet1
type zeroGradient;
inlet2
type zeroGradient;
symmetric1
type slip;
symmetric2
type slip;
T
boundaryField
blade
type zeroGradient;
outlet
type zeroGradient;//????
inlet1
type fixedValue;
value uniform 540;
inlet2
type fixedValue;
value uniform 300;
symmetric1
type slip;
symmetric2
type slip;
xinsui178 is offline   Reply With Quote
Old   August 25, 2017, 10:20
Ketan Ganatra
ketanganatra0@yahoo.com is on a distinguished road
Hi friend
I am also running with buoyantboussinesqsimplefoam and the same error I am also getting.
Can you please send me your O constant and system file to me???
You can see my case in following link.
http://https://drive.google.com/driv...095RUlEbXpMU28
Please reply as soon as possible it would be helpful for both of us.
ketanganatra0@yahoo.com is offline   Reply With Quote
Old   August 25, 2017, 10:24
sturgeon is on a distinguished road
I am new to OpenFOAM but I have been messing around in bBSF and had similar errors so possibly I can help.
Is that your file for p or p_gh?
(Also might help if you use the code tags to surround the text or upload whole case file)
sturgeon is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
