June 29, 2016, 07:29 |
#21 |
Rep Power: 11 |
you haven't set any residualControl to PIMPLE as I suggested earlier: Code:
PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Again, to reach a converged solution, add residualControl to PIMPLE, there are several examples available for example here |
June 29, 2016, 07:42 |
#22 |
Asmaa
Rep Power: 10 |
Thank you for your fast reply .
Please find attached my fvsolution, I've modified it, is it ok or i should add something else? |
June 29, 2016, 11:28 |
#23 |
Asmaa
Rep Power: 10 |
Yes it seems that my system is generating mass!!! so what can I do to solve this problem?
June 30, 2016, 02:20 |
#24 |
Rep Power: 11 |
You need to make your simulation converge. Try it with your new fvSolution settings and you should see a difference.
June 30, 2016, 06:55 |
#25 |
Asmaa
Rep Power: 10 |
Yes it converges now!! thank you very much
Please do you have any idea about how to calculate torque and forces in multiphase, because with simpleFoam I use functions ( forces { type forces; functionObjectLibs ("libforces.so"); outputControl timeStep; outputInterval 1; patches (wall_impeller_1 wall_shaft-fluid_tank wall_shaft-fluid_mrf_1); pname p; Uname U; rhoName rhoInf; log true; rhoInf 998; CofR (0 0 0); } ); But when I use it with multiphase case, I get this error: --> FOAM FATAL ERROR: No valid model for viscous stress calculation From function forces::devRhoReff() in file forces/forces.C at line 258. FOAM exiting |
How to simulate the eulerian multiphase model about particle | jhlee9622 | STAR-CCM+ | 2 | November 24, 2016 12:37 |
Low Mach Number Compressible Multiphase Flows | DarrenC | CFX | 10 | May 26, 2014 09:52 |
VOF multiphase - Validity of Fluent ? | manxu | FLUENT | 2 | January 2, 2014 12:17 |
Difference of multicomponent and multiphase homogenous flows | Luk_Fiz | CFX | 11 | April 4, 2013 06:29 |
multiphase multicomponent physics | ckleanth | CFX | 3 | June 4, 2009 21:15 |
