June 14, 2016, 04:30 |
XiFoam combustion approach
Naman Jain
Rep Power: 11 |
Hello everyone,
I am trying to simulate a 2D premixed combustion reaction to study the flame using the solver XiFoam. In my case, I have an inlet jet of 20mm X 100mm which opens up in a slot of 200mm X 800mm, with the slot being the combustor. I am trying to model a case in which a fuel mixture comes from the inlet and is ignited at the jet exit (i.e. when it enters the combustor chamber). For that I set the value of b as 1 at the inlet and b as 0 in the rest of the domain and specified an inlet velocity and after sometime ignite the flow. This seems to me the only approach. However I have read in the forum that this might not be the right approach as I am creating an infinite gradient of b, which would mean that the reaction rate is infinite in an infinitesimal region. Any comments on this? If I should change my approach, then what else should I try? Thanks for your time, Naman. |
XiFoam lean-premixed combustion instabilities | remir | OpenFOAM Running, Solving & CFD | 8 | April 15, 2016 09:31 |
combustion, XiFoam, ignitionSphereFraction | achinta | OpenFOAM | 1 | July 30, 2012 07:40 |
Turbulent combustion error... XiFoam model | achinta | OpenFOAM | 1 | July 7, 2010 09:24 |
Turbulent premixed combustion error... XiFoam model | achinta | OpenFOAM | 1 | June 23, 2010 06:45 |
Simple approach - solid wood combustion (newbie..) | Dan | Main CFD Forum | 0 | December 3, 2007 03:06 |
