June 12, 2016, 03:37 |
Unknown Error
Saber
Rep Power: 10 |
Good morning People
I am trying to mesh a geometry with snappyhexmesh. That worked great. Now want to run pisoFoam and decompose that after. But OpenFoam then just show me that error: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.1-bcfaaa7b8660 Exec : decomposePar Date : Jun 12 2016 Time : 09:27:47 Host : "pk" PID : 21298 Case : /home/diana/OpenFOAM/diana-2.3.1/neuerVersuch nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Decomposing mesh region0 Create mesh Calculating distribution of cells Selecting decompositionMethod scotch Finished decomposition in 3.89 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 635542 Number of faces shared with processor 1 = 1054 Number of processor patches = 1 Number of processor faces = 1054 Number of boundary faces = 121437 --> FOAM FATAL ERROR: Cell 919contains face labels out of range: 6(2997 2998 2999 3000 -1 2992) Max face index = 2055946 From function polyMesh:olyMesh ( const IOobject&, const Xfer<pointField>&, const Xfer<faceList>&, const Xfer<cellList>& ) in file meshes/polyMesh/polyMesh.C at line 654. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::Xfer<Foam::List<Foam::face> > const&, Foam::Xfer<Foam::List<Foam::cell> > const&, bool) at ??:? #3 at ??:? #4 at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 at ??:? ^CAborted (core dumped) Does anyone has an Idea what I made wrong? |
June 12, 2016, 04:37 |
Pedro
Rep Power: 11 |
Could you please run the comand "checkMesh. It will print out a log with possible errors in the Mesh.
June 12, 2016, 06:35 |
Saber
Rep Power: 10 |
diana@pk:~/OpenFOAM/diana-2.3.1/neuerVersuch2$ checkMesh
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.1-bcfaaa7b8660 Exec : checkMesh Date : Jun 12 2016 Time : 12:34:44 Host : "pk" PID : 24811 Case : /home/diana/OpenFOAM/diana-2.3.1/neuerVersuch2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 762410 faces: 2108375 internal faces: 1939810 cells: 673627 faces per cell: 6.009535 boundary patches: 16 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 629558 prisms: 30328 wedges: 0 pyramids: 0 tet wedges: 17 tetrahedra: 0 polyhedra: 13724 Breakdown of polyhedra by number of faces: faces number of cells 4 53 5 799 6 608 7 460 9 11198 12 606 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology maxY 0 0 ok (empty) minX 2432 2541 ok (non-closed singly connected) maxX 2432 2541 ok (non-closed singly connected) minY 0 0 ok (empty) minZ 0 0 ok (empty) maxZ 0 0 ok (empty) inlet_1 912 1071 ok (non-closed singly connected) inlet_2 912 1143 ok (non-closed singly connected) inlet_3 912 1143 ok (non-closed singly connected) inlet_4 905 1069 ok (non-closed singly connected) inlet_5 906 1136 ok (non-closed singly connected) inlet_6 904 1069 ok (non-closed singly connected) inlet_7 858 1076 ok (non-closed singly connected) inlet_8 858 1008 ok (non-closed singly connected) outlet 1520 1617 ok (non-closed singly connected) casing 155014 156939 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0.277 0.20299501 0.74999845) (0.527 0.83880103 1.7500003) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-3.6109514e-16 4.3811878e-15 1.4820177e-16) OK. Max cell openness = 3.1918271e-16 OK. Max aspect ratio = 5.5901407 OK. Minimum face area = 1.2105523e-07. Maximum face area = 0.00030942757. Face area magnitudes OK. Min volume = 3.543095e-10. Max volume = 3.2021256e-06. Total volume = 0.13153312. Cell volumes OK. Mesh non-orthogonality Max: 60.461273 average: 5.1332881 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.1192572 OK. Coupled point location match (average 0) OK. Mesh OK. End diana@pk:~/OpenFOAM/diana-2.3.1/neuerVersuch2$ |
Saber
Rep Power: 10 |
Thatīs the result of checkMesh.
June 13, 2016, 02:55 |
Marco Atzori
Rep Power: 10 |
Hi!
Maybe I had a similar problem in the past, but I cannot remember well: are you allowed to share the case, to reproduce the issue? BTW, did you see the post #17 (October 24, 2015, 10:08) in this thread? http://www.cfd-online.com/Forums/ope...out-range.html Best Regards! Marco Atzori |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
