Problem with pressure when using "empty" and unstructured mesh |
June 9, 2016, 14:07 |
Andrea
Rep Power: 10 |
Hello!
I'm relatively new to OpenFoam and I'm having trouble when using the "empty" condition. I'm trying to model some kind of nozzle (pictures included) and due to problem's conditions, I can assume that the flow is axisymmetric. Therefore, I used empty for the front and back of my model, walls for top and bottom and patch for inlet and outlet. I'm using an unstructured mesh with an average non-orthogonality of 19.7421. I used kEpsilon Model for turbulence, bounded Gauss linearUpwind for numerical schemes and 1 nonOrthogonalCorrector. I defined velocity at inlet and pressure at outlet. When I run the simulation, I get a weird pressure distribution: P_empty.jpg And also problems with the velocity, as if somehow the cells from the mesh could be seen: U_empty_2.jpg When trying to find a solution to this problem, I decided to try symmetryPlane instead of empty, and I noticed that these problems don't seem to appear (all other settings remained the same) P_symm.jpg U_symm_1.jpg Because of this, I'm lead to believe that "empty" has specific requirements regarding the mesh, but until now I haven't found information about unstructured meshes and empty condition. Does anyone have any idea why empty doesn't seem to work with my unstructured mesh?? I would really appreciate any suggestion!!! Thanks |
axisymmetric, empty, openfoam, symmetryplane, unstructured |
Unstructured mesh problem | giangcoikx | Pointwise & Gridgen | 0 | April 8, 2016 09:49 |
[Commercial meshers] Problem with export unstructured mesh in OpenFOAM | AdrianoCT | OpenFOAM Meshing & Mesh Conversion | 2 | June 24, 2015 04:56 |
Problem unstructured mesh domain drilled by a cylinder | obliz | ANSYS | 0 | July 16, 2014 17:40 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
