Spilway - Dt becomes very small
Old   June 8, 2016, 13:24
Talking Spilway - Dt becomes very small
Ivan Daniel
IvanD is on a distinguished road
I am running a simulation of a spilway in OpenFOAM 2.1.0.
But I run with InterFoam, the solution doesn't converge.
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application interFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 30;
deltaT 0.001;
writeControl adjustableRunTime;
writeInterval 0.05;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep on;
maxCo 1;
maxAlphaCo 1;
maxDeltaT 1;
functions
#include "forceCoeffs"
Courant Number mean: 9.42647e+29 max: 1.18631e+37
Interface Courant Number mean: 1.40504e+29 max: 3.86991e+35
deltaT = 3.59664e-70
--> FOAM Warning :
From function Time:perator++()
in file db/Time/Time.C at line 1061
Increased the timePrecision from 8 to 9 to distinguish between timeNames at time 0.00126071
Time = 0.00126071193
PIMPLE: iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 1.58718e-07, Final residual = 5.62181e-12, No Iterations 1
Phase-1 volume fraction = 0.425401 Min(alpha.water) = -0.12434 Max(alpha.water) = 1.41534
MULES: Correcting alpha.water
DILUPBiCG: Solving for Ux, Initial residual = 0.999999, Final residual = 2.75158e-13, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 9.96478e-14, No Iterations 1
DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0496977, No Iterations 9
time step continuity errors : sum local = 5.98339e-09, global = -1.08509e-24, cumulative = 3.33729e+12
DICPCG: Solving for p_rgh, Initial residual = 8.91644e-08, Final residual = 8.91644e-08, No Iterations 0
time step continuity errors : sum local = 1.31943e+17, global = 0.156645, cumulative = 3.33729e+12
DICPCG: Solving for p_rgh, Initial residual = 8.91798e-08, Final residual = 8.91798e-08, No Iterations 0
time step continuity errors : sum local = 1.31966e+17, global = -1.12582, cumulative = 3.33729e+12
I don't think the problem is the mesh, because I believe I did well.
I'm practicing an example of this page: https://www.hpc.ntnu.no/display/hpc/...llway+Tutorial , but for me it doesn't work, can be the version of OpenFOAM.
IvanD is offline   Reply With Quote
controldict, interfoam, spillway
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 04:15
[snappyHexMesh] meshing of very small patches in comparison with the overall geometry christos OpenFOAM Meshing & Mesh Conversion 3 December 17, 2014 17:55
Simulating small features on large models siw CFX 1 February 16, 2012 18:10
Small influence of convection in PISO if Courant number is small sebi OpenFOAM 0 February 22, 2011 15:55
small size holes simulation brian ko Phoenics 5 October 22, 2001 13:53
