boundary conditions and errors
Old   June 6, 2016, 18:47
Default boundary conditions and errors
KTG
Abe
KTG is on a distinguished road
Hi Foamers,
I am new to openFOAM, and am having some trouble understanding the boundary conditions. I am setting up a very simple interfoam case. It is a Hele-Shaw type experiment where a light, low viscosity fluid is displaced by a denser, high viscosity one. The domain is a rectangle, where fluid flows between two flat plates that are close together (like Poiselle flow, but two phase). The geometry and viscosity make the Reynolds number low enough to disregard turbulence. I am pretty confident that I setup blockmesh and alpha.water properly, but probably not boundary conditions. I am getting this error message that I don't understand:
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so"
#2  ? in "/lib64/libc.so.6"
#3  ? in "/lib64/libm.so.6"
#4  Foam::pow(Foam::dimensioned<double> const&, Foam::dimensioned<double> const&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so"
#5  Foam::interfaceProperties::interfaceProperties(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::IOdictionary const&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libinterfaceProperties.so"
#6  Foam::immiscibleIncompressibleTwoPhaseMixture::immiscibleIncompressibleTwoPhaseMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libimmiscibleIncompressibleTwoPhaseMixture.so"
#7  ? in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/interFoam"
#8  __libc_start_main in "/lib64/libc.so.6"
#9  ? in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/interFoam"
Floating point exception (core dumped)
The impression I get is that the boundary conditions I set up are causing openFoam to calculate some paradoxical flux values or something.
Here are my blockMesh, p_rgh, and U setups:
|  \\    /   O peration     | Version:  v3.0+                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (0 0 0)
    (.1 0 0)
	(.1 .16 0)
	(0 .16 0)
    (0 0 -.001)
    (.1 0 -.001)
	(.1 .16 -.001)
	(0 .16 -.001)
blocks
    hex (0 1 2 3 4 5 6 7) (30 30 10) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (1 5 6 2)
    outlet
        type patch;
        faces
            (0 3 7 4)
            (3 2 6 7)
    wedgewalls
        type wall;
        faces
            (0 1 2 3)
            (4 7 6 5)
			(0 4 5 1)
mergePatchPairs
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            prghPressure;
        rho             1263.9;
		href			.16;
        p               uniform 0;
        value           uniform 0; // optional initial value
    outlet
        type            fixedValue;
		value			uniform 0;
	wedgewalls
        type            fixedFluxPressure;
        value           uniform 0;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
		type			zeroGradient;
    outlet
        type            zeroGradient;
    wedgewalls
        type            fixedValue;
        value           uniform (0 0 0);
The flow is driven by the constant hydrostatic pressure on the "inlet" boundary where the heavier fluid enters. The lighter displaced fluid should exit the "outlet" boundary, with the only resistance being a little drag on the walls and atmospheric pressure. So I set atmospheric to zero, so that I wouldn't have to add it to the rghPressure boundary in the p_rgh file. I think the problem is in the U inlet or outlet boundaries. I don't know the actual velocity at either boundary, so I really just guessed fixedGradient. Does this just mean that velocity is constant in the direction normal to the boundary? I seem to have some deficiencies in understanding what the openFoam documentation means mathematically. I have been trying to use the documentation: http://openfoam.github.io/Documentat...ml/a00003.html , but it is pretty overwhelming at this point. All suggestions welcome! Also, if anyone has any tips about using the documentation / learning the boundary conditions....
Thanks-
KTG is offline   Reply With Quote
beginner, boundary condition, documentation, hele-shaw cell
[ICEM] errors in defining periodic boundary conditions ahirekar10 ANSYS Meshing & Geometry 1 May 5, 2014 05:21
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Is there any method to analyse the errors cause by boundary conditions? hadesmajesty Main CFD Forum 1 August 9, 2009 10:47
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 09:59
