How to calculate the flux of this term grad(alpha1)*alphaf*U?
Old   June 6, 2016, 11:26
Default How to calculate the flux of this term grad(alpha1)*alphaf*U?
David Long
keepfit is on a distinguished road
Hi Foamers,
I am working on a modified solver based on interFoam, having problem to calculate the flux of the following term (in modified VOF method):
where alpha1 is the liquid phase volume fraction, alphaf the fluid volume fraction, and U the fluid velocity. The term alphaf is introduced because there is a third phase: solid.
To calculate the flux of this term, I tried the following code:
volVectorField afGrada1("afGrada1", alphaf*fvc::grad(alpha1));
//volVectorField afGrada1("afGrada1", alphaf*fvc::snGrad(alpha1));
surfaceScalarField afGrada1Uf(fvc::interpolate(U*afGrada1) & mesh.Sf());
But it seems that there is a problem on the gradient of alpha1.
alphaEqn.H: In function ‘int main(int, char**)’:
alphaEqn.H:16:69: error: no matching function for call to ‘Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(const char [9], Foam::tmp<Foam::Field<double> >)’
alphaEqn.H:16:69: note: candidates are: ...........
I have tried a bot of combinations, but none is working. Any advice to calculate alphaf*grad(alpha1)?
Thanks in advance.
keepfit is offline   Reply With Quote
Old   June 7, 2016, 06:37
Balajee
bala_gk1988 is on a distinguished road
U*afGrada1
Both U and afGrada1 are volVectorFields. You are taking outer product of those two vector fields, which produces a volTensorField.
The inner product of that volTensorField with mesh.Sf()should produce a vector field not a scalar field.
bala_gk1988 is offline   Reply With Quote
Old   June 9, 2016, 16:08
David Long
Originally Posted by bala_gk1988 View Post
U*afGrada1
thanks for your reply, bala_gk1988!
I was not aware of this problem. I tried the following code (no compile error)
volVectorField afGrada1("afGrada1", a1af*fvc::grad(alpha1));
volScalarField afGrada1U("afGrada1U", afGrada1&U);
surfaceScalarField Phi_afGrada1Uf("Phi_afGrada1Uf", fvc::interpolate(afGrada1U) * mesh.magSf());
however, it seems the result of Phi_afGrada1Uf is not compatible with fvc::flux(a, b, scheme).
LHS and RHS of + have different dimensions
     dimensions : [0 3 -1 0 0 0 0] + [0 2 -1 0 0 0 0]
it seems that i need to dig into the fvc:flux(...) code
Hi please tell me how can calculate heat flux in duct ? is draw line on surface ? reslan FLUENT 0 February 26, 2016 17:27
Hi i need to find surface heat flux is draw line on surface to calculate hlocal? reslan FLUENT 0 February 25, 2016 18:21
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Calculate diameter of a 3D vessel as a function of flux, Re and Wall shear stress kamran_kibria Main CFD Forum 0 October 20, 2010 17:38
How to calculate the flux? YW FLUENT 2 November 10, 2003 14:45
