Sudden pressure drop - Multiphase Flow
Old   June 6, 2016, 07:04
Default Sudden pressure drop - Multiphase Flow
koscfd is on a distinguished road
I created a pipe model in Salome software and imported it in OF for a transient analysis (65s). The flow has two phases and the solver is interFoam. I set the flow from inlet to outlet and run the analysis. The pressure results were reasonable (relatively uniform) for each phase.
When I set the flow the other way round (outlet to inlet), I get sudden and random downward peaks in the pressure field.
For example, at times from 0s to 16.3s pressure results are normal. At time 16.4 the pressure drops significantly (5-6 times less pressure). From times 16.5s to 20.2 results are ok. At time 20.3 the pressure drops significantly. ... and so on.
Do you have any suggestions why could this be happening?
Thank you in advance,
koscfd
koscfd is offline   Reply With Quote
Old   July 8, 2016, 07:17
katete is on a distinguished road
I am too working on two-phase pipe flow in interFoam. Could you post the model setup (esp. the boundary conditions)? Then it might be easier to understand your case.
Thanks and best wishes
Katharina
katete is offline   Reply With Quote
Old   July 8, 2016, 08:42
Hello Katharina,
Thank you for your reply.
I have attached the model properties.
I also tried setting 0 pressure (fixedValue) at the pipe outlet, however I still get sudden peaks in pressure results.
Kind Regards,
Kos
Old   August 25, 2016, 09:22
Hey Kos,
I had a look at your case but figured that your simulations are quite different than mine. You are changing the inlet phase as a function of time which I haven't done before. What I could think of since you don't have problems in the positive flow direction: Maybe it is related to the coordinate system? maybe your model has some negative coordinates that might cause problems? Or have you tried turning the whole geometry that the flow is still in positive x-direction? Otherwise I also don't know what you might improve.
Kind regards
Katharina
Appropriate pressure boundary condition in incompressible flow lonelywing OpenFOAM Running, Solving & CFD 21 June 6, 2022 10:44
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
Modelling the two-phase flow Pressure Drop in a helical coil Lancashire Fluent Multiphase 4 August 12, 2015 05:49
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
