Maximum number of iterations exceeded - rhoSimpleFoam |
June 5, 2016, 17:01 |
A Z
Rep Power: 11 |
Hi everyone,
I'm try to simulate a Pipe using rhoSimpleFoam. I get after a few teps the "Maximum number of iterations exceeded" error. I tried some solutions I found here but without results. (changing the relaxationFactors & schemes, setting TMin, Tmax ... , checking and changing Boundary Conditions) The Mesh looks fine. Below the logfile: Code:
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.001 field U tolerance 0.001 field h tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; } No MRF models present No finite volume options present Starting time loop Time = 1e-05 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.022547925, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.055572477, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.05735183, No Iterations 3 smoothSolver: Solving for h, Initial residual = 0.99560741, Final residual = 0.00054553968, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 6.8005097e-09, No Iterations 35 GAMG: Solving for p, Initial residual = 0.029825433, Final residual = 7.8671775e-09, No Iterations 17 GAMG: Solving for p, Initial residual = 0.0016980265, Final residual = 8.9338721e-09, No Iterations 13 time step continuity errors : sum local = 7.1954987e-10, global = -9.7011997e-12, cumulative = -9.7011997e-12 rho max/min : 1.2639489 1.2014065 smoothSolver: Solving for epsilon, Initial residual = 0.18539279, Final residual = 0.018263051, No Iterations 2 bounding epsilon, min: -1.0623939 max: 113.81697 average: 1.8930911 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.097817915, No Iterations 2 ExecutionTime = 251.38 s ClockTime = 251 s Time = 2e-05 smoothSolver: Solving for Ux, Initial residual = 0.028023654, Final residual = 0.00072812086, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.36155382, Final residual = 0.033268639, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.33901192, Final residual = 0.0069851927, No Iterations 1 smoothSolver: Solving for h, Initial residual = 2.885836e-06, Final residual = 6.91766e-09, No Iterations 1 GAMG: Solving for p, Initial residual = 0.021754383, Final residual = 5.2425385e-09, No Iterations 31 GAMG: Solving for p, Initial residual = 0.88325208, Final residual = 8.0467665e-09, No Iterations 26 GAMG: Solving for p, Initial residual = 0.20759689, Final residual = 8.2151254e-09, No Iterations 22 time step continuity errors : sum local = 2.9362986e-08, global = 2.2426915e-10, cumulative = 2.1456795e-10 rho max/min : 1.4111591 1.1097508 smoothSolver: Solving for epsilon, Initial residual = 0.99460634, Final residual = 0.087019508, No Iterations 3 bounding epsilon, min: -4188.6099 max: 58007085 average: 1010.3673 smoothSolver: Solving for k, Initial residual = 0.99980048, Final residual = 0.072515354, No Iterations 3 bounding k, min: -56.453502 max: 8.5420722e+08 average: 820.94691 ExecutionTime = 503.97 s ClockTime = 504 s Time = 3e-05 smoothSolver: Solving for Ux, Initial residual = 0.72842759, Final residual = 0.01241609, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.63153151, Final residual = 0.028186555, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.72692847, Final residual = 0.056586838, No Iterations 2 smoothSolver: Solving for h, Initial residual = 1, Final residual = 0.0014389051, No Iterations 1 GAMG: Solving for p, Initial residual = 0.98094699, Final residual = 8.5390336e-09, No Iterations 54 GAMG: Solving for p, Initial residual = 6.8142427e-06, Final residual = 7.5921063e-09, No Iterations 14 GAMG: Solving for p, Initial residual = 5.3619733e-06, Final residual = 7.6303402e-09, No Iterations 5 time step continuity errors : sum local = 0.0049250584, global = -9.5693406e-05, cumulative = -9.5693192e-05 rho max/min : 1.5289273 1.0278007 smoothSolver: Solving for epsilon, Initial residual = 0.83663086, Final residual = 0.080689562, No Iterations 2 bounding epsilon, min: -2182.0455 max: 1.0398029e+16 average: 9.9707159e+09 smoothSolver: Solving for k, Initial residual = 0.99736547, Final residual = 0.069018573, No Iterations 3 bounding k, min: -199.49558 max: 9.9985416e+13 average: 1.6617361e+08 ExecutionTime = 745.56 s ClockTime = 747 s Time = 4e-05 smoothSolver: Solving for Ux, Initial residual = 0.43323326, Final residual = 0.011644508, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.25795325, Final residual = 0.010723061, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.29775014, Final residual = 0.0085255883, No Iterations 1 smoothSolver: Solving for h, Initial residual = 0.089014636, Final residual = 0.00040056378, No Iterations 1 --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>] in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::THs(double, double, double) const at ??:? #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Abort (core dumped) Code:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 3151471 faces: 8646263 internal faces: 8378086 cells: 2760772 faces per cell: 6.1665176 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 2297184 prisms: 73432 wedges: 0 pyramids: 0 tet wedges: 800 tetrahedra: 2 polyhedra: 389354 Breakdown of polyhedra by number of faces: faces number of cells 4 24349 5 16295 6 21202 7 206911 8 47896 9 50514 10 1042 11 352 12 15902 13 32 14 70 15 4696 16 1 17 1 18 91 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 4097 4165 ok (non-closed singly connected) outlet_beifahrer 6283 7226 ok (non-closed singly connected) outlet_fahrer 6262 7211 ok (non-closed singly connected) wall 251535 276060 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (1.315 -0.38629527 -0.10150999) (3.3232987 0.38629978 0.042797109) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.0739519e-16 1.9630194e-16 1.0030706e-16) OK. Max cell openness = 1.6036898e-15 OK. Max aspect ratio = 43.785327 OK. Minimum face area = 3.457976e-10. Maximum face area = 1.8677262e-05. Face area magnitudes OK. Min volume = 8.0322233e-13. Max volume = 8.0108398e-08. Total volume = 0.012347979. Cell volumes OK. Mesh non-orthogonality Max: 64.69395 average: 8.0658553 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 10.13589, 75 highly skew faces detected which may impair the quality of the results <<Writing 75 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } dimensions [ 0 1 -1 0 0 0 0 ]; internalField uniform ( 0 0 0 ); boundaryField { inlet { type fixedValue; value uniform ( 20 0 0 ); } outlet_fahrer { type inletOutlet; value uniform ( 0 0 0 ); inletValue uniform ( 0 0 0 ); } outlet_beifahrer { type inletOutlet; value uniform ( 0 0 0 ); inletValue uniform ( 0 0 0 ); } wall { type fixedValue; value uniform ( 0 0 0 ); } } Code:
FoamFile { object T; } dimensions [0 0 0 1 0 0 0]; internalField uniform 293.15; boundaryField { wall { type zeroGradient; } inlet { type fixedValue; value $internalField; } outlet_fahrer { type inletOutlet; value $internalField; inletValue $internalField; } outlet_beifahrer { type inletOutlet; value $internalField; inletValue $internalField; } } Code:
FoamFile { object p; } dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { wall { type zeroGradient; } outlet_fahrer { type fixedValue; value uniform 101325; } outlet_beifahrer { type fixedValue; value uniform 101325; } inlet { type zeroGradient; } } Code:
{ object k; } dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.01500; //82.876 boundaryField { wall { type kqRWallFunction; value $internalField; } inlet { type fixedValue; //turbulentIntensityKineticEnergyInlet; //intensity 0.03804; value $internalField; } outlet_fahrer { type inletOutlet; inletValue $internalField; value $internalField; } outlet_beifahrer { type inletOutlet; inletValue $internalField; value $internalField; } } Code:
FoamFile { object epsilon; } dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.008366; boundaryField { wall { type epsilonWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value $internalField; } inlet { type fixedValue; //type turbulentMixingLengthFrequencyInlet; // mixingLength 0.0019; value $internalField; } outlet_fahrer { type inletOutlet; inletValue $internalField; value $internalField; } outlet_beifahrer { type inletOutlet; inletValue $internalField; value $internalField; } } Code:
FoamFile { object fvSchemes; } ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; //new } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); //bounded Gauss upwind; div(phi,h) bounded Gauss linearUpwind grad(U); //bounded Gauss upwind; div(phi,k) bounded Gauss linearUpwind grad(U); //bounded Gauss upwind; div(phi,K) bounded Gauss linearUpwind grad(U); //bounded Gauss upwind; div(phi,epsilon) bounded Gauss linearUpwind grad(U); //bounded Gauss upwind; div(phi,omega) bounded Gauss linearUpwind grad(U); //bounded Gauss upwind; div(U,p) bounded Gauss linearUpwind grad(U); //bounded Gauss upwind; div(phi) bounded Gauss linearUpwind grad(U); //bounded Gauss upwind; //div((muEff*dev2(T(grad(U))))) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; //Gauss linear corrected; } laplacianSchemes { default none; laplacian(muEff,U) Gauss linear corrected; laplacian((rho|A(U)),p) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DomegaEff,omega) Gauss linear corrected; laplacian(alphaEff,h) Gauss linear corrected; laplacian(mut,U) Gauss linear corrected; laplacian((rho*(1|A(U))),p) Gauss linear corrected; laplacian(yPsi) Gauss linear corrected; laplacian((rho*nuEff),U) Gauss linear corrected; laplacian((rho*DomegaEff),omega) Gauss linear corrected; laplacian((rho*DepsilonEff),epsilon) Gauss linear corrected; laplacian((rho*DkEff),k) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } wallDist { method Poisson; // Optional entry enabling the calculation // of the normal-to-wall field nRequired false; } snGradSchemes { default corrected; } fluxRequired { default no; p; } Code:
FoamFile { object fvSolution; } solvers { p { solver GAMG; preconditioner GAMG; tolerance 1e-8; //war 1e-7 relTol 0; //war 0.1 smoother DICGaussSeidel; //war GaussSeidel nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; //war 10 mergeLevels 1; directSolveCoarsest false; //war nicht vorhanden }; U { /* // solver smoothSolver; // smoother GaussSeidel; // nSweeps 2; solver PBiCG; preconditioner DILU; tolerance 1e-7; relTol 0.01; */ solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; }; h { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0.1; /* solver PBiCG; preconditioner DILU; tolerance 1e-5; relTol 0.1; */ }; k { solver smoothSolver; smoother GaussSeidel; nSweeps 1; //war 2 tolerance 1e-8; //war 5 relTol 0.1; }; epsilon { solver smoothSolver; smoother GaussSeidel; nSweeps 1; //war 2 tolerance 1e-8; //war 5 relTol 0.1; }; omega { solver smoothSolver; smoother GaussSeidel; nSweeps 1; //war 2 tolerance 1e-8; //war 5 relTol 0.1; }; yPsi { solver PCG; preconditioner DIC; tolerance 1e-5; relTol 0; } } SIMPLE { nUCorrectors 2; nNonOrthogonalCorrectors 2; //war 5 //pMin pMin [1 -1 -2 0 0 0 0] 0; TMin TMin [0 0 0 1 0 0 0] 283; Tmax TMax [0 0 0 1 0 0 0] 313; rhoMin rhoMin [1 -3 0 0 0 0 0] 0.7; rhoMax rhoMax [1 -3 0 0 0 0 0] 2; residualControl { p 1e-3; U 1e-3; h 1e-3; "(k|epsilon|omega)" 1e-3; } } relaxationFactors { p 0.2; //war 0.2 rho 0.2; //war 0.2 U 0.6; //war 0.6 h 0.1; //war 0.6 k 0.6; //war 0.6 epsilon 0.6; //war 0.6 omega 0.6; //war 0.6 } |
July 6, 2016, 06:24 |
carno
Rep Power: 17 |
Are you using simpleFoam solution to initialize this? Or using simpleFoam files?
March 29, 2017, 07:52 |
Attesz
Rep Power: 17 |
Hi don6alfonso, did you find a solution to your problem at the end?
March 29, 2017, 09:21 |
A Z
Rep Power: 11 |
rhosimplefoam |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 03:42 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
