June 5, 2016, 13:38 |
buoyantPimpleFoam setup for oil heating
Vilma62
Rep Power: 11 |
Hello All,
I am trying to simulate oil heating and fluid flow within the cavity. The flow is induced by buoyancy only. The first attempt, by using buoyantBoussinesqPimpleFoam solver runs quite nicely, but when the buoyantPimpleFoam solver is invoked, the simulation crashes soon after the start: Code:
Starting time loop Courant Number mean: 0 max: 0 Time = 0.05 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.001769244, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.7380157, Final residual = 1.57685e+008, No Iterations 100 GAMG: Solving for p_rgh, Initial residual = 0.9516482, Final residual = 1561.276, No Iterations 100 GAMG: Solving for p_rgh, Initial residual = 0.9632775, Final residual = 48.57067, No Iterations 100 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 3.729934e+011, global = 0.0002506613, cumulative = 0.0002506613 GAMG: Solving for p_rgh, Initial residual = 0.9792977, Final residual = 6.278125e+010, No Iterations 100 GAMG: Solving for p_rgh, Initial residual = 0.9753959, Final residual = 3.375873e+009, No Iterations 100 GAMG: Solving for p_rgh, Initial residual = 0.9655519, Final residual = 1.459729e+010, No Iterations 100 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.038088e+016, global = 1, cumulative = 1.000251 PIMPLE: iteration 2 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 6.087396e+032, No Iterations 1001 GAMG: Solving for p_rgh, Initial residual = nan, Final residual = nan, No Iterations 100 GAMG: Solving for p_rgh, Initial residual = nan, Final residual = nan, No Iterations 100 --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 9 the word 'nan' file: C:/Temp/Tube_buoyantPimpleFoam/system/data.solverPerformance.p_rgh at line 9. From function operator>>(Istream&, Scalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting I would appreciate very much your help. Thank you in advance. Last edited by Vilma62; March 15, 2019 at 07:06. |
2D Glass Melt Simulation Setup | marmz | FLUENT | 5 | October 9, 2016 15:25 |
is it possible to modelize induction heating in a frequency domain with OpenFOAM? | julien23 | OpenFOAM | 0 | January 12, 2015 05:47 |
[ICEM] surface/curve mesh setup | Studi | ANSYS Meshing & Geometry | 15 | November 12, 2014 00:32 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
Heating value of fuel in non-premixed model? | Jeronimo97 | FLUENT | 0 | February 15, 2013 14:27 |
