How to find Mass flow at the inlet and outlet patch
Old   June 3, 2016, 14:02
Default How to find Mass flow at the inlet and outlet patch
Sheikh Ahmed
sahmed is on a distinguished road
Hi
Could anyone please share your thoughts about how can I find the mass flow at the inlet and outlet patches for a flow through a tube with minimum effor in OpenFOAM? I am using OF version 2.3.1 and I think 'calcMassFlow' utility works with the older versions. Any of your suggestion will be highly appreciated.
sahmed is offline   Reply With Quote
Old   June 3, 2016, 15:52
Balajee
bala_gk1988 is on a distinguished road
patchIntegrate phi patchname
bala_gk1988 is offline   Reply With Quote
Old   June 3, 2016, 17:12
Sheikh Ahmed
Thanks for your reply. Could you please tell me what is the 'phi' here. The Patchname here is the inlet and outlet for my case I believe.
Also, is this an openFoam command to find the mass flow?? PLEASE tell me a little more details.
Thanks once again.
Old   June 6, 2016, 12:47
Sheikh Ahmed
Hi Balajee
Thanks for your sharing. I came to learn that 'patchIntegrae phi patchname -latestTime' is the openfoam command to integrate the quantity 'phi' that is calculated when I select the fluxRequired option in the system/fvSchemes as "p", changing from the default 'no'. The last line of the output from this command gives the integral of phi over the specified patch, which is nothing but the mass flow (in mass/time).
Is that correct? Please correct me if I am wrong.
Old   June 7, 2016, 06:24
Balajee
Yes. phi is a surfaceScalarField and it represents the mass flux across the faces. And patchIntegrate integrates phi over all the boundary faces in the patch and gives you the mass flux through that patch.
mass flow
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet coolcrasher OpenFOAM Post-Processing 7 November 4, 2021 05:57
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 06:58
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 11:09
