"nan" problem
Like Tree2Likes
Old   June 10, 2016, 06:53
Asmaa
foamiste is on a distinguished road
This is my gemoetry, I am setting all boundaries as walls except the liquid level whitch is defined as symmetryPlane. For 0:
p_rgh: fixedFluxPressure ($internaField)
U: fixedValue ($internalField)
T: fixedValue ($internalField)
alpha: zerogradient
foamiste is offline   Reply With Quote
Old   June 13, 2016, 12:34
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
alpha: zerogradient
Ok. I'm sorry I'm out of easy ideas since I'm not very expert about MRF and stirred vessels. Hope someone could help more!
foamiste likes this.
rdbisme is offline   Reply With Quote
Old   January 25, 2018, 09:20
Default similar probelem
  #23
Foad
foadsf is on a distinguished road
hello guys, I have also asked this question on reddit and openfoam google group
I kinda have a same issue as the OP so I post here too.
I'm following this tutorial for compressible fluid. except my geometry is little bit different:
But when I try to solve it with sonicFoam I get the error below:
Time = 0.002
Courant Number mean: 62.7429 max: 120
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 0.738285, Final residual = 0.357953, No Iterations 1000
smoothSolver:  Solving for Uy, Initial residual = 0.0131426, Final residual = 4.93472e-018, No Iterations 1
smoothSolver:  Solving for e, Initial residual = 1, Final residual = nan, No Iterations 1000
smoothSolver:  Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000
time step continuity errors : sum local = nan, global = nan, cumulative = nan
PIMPLE: iteration 2
smoothSolver:  Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver:  Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver:  Solving for e, Initial residual = nan, Final residual = nan, No Iterations 1000
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 0 the word 'nan'
file: C:/Users/.../20180124/system/data.solverPerformance.e at line 0.
    From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&)
    in file lnInclude/Scalar.C at line 93.
FOAM exiting
I would appreciate if you could help me know what is the problem and how I can solve it
foadsf is offline   Reply With Quote
Old   January 25, 2018, 10:43
rdbisme's Avatar
Ruben Di Battista
Time = 0.002
PIMPLE: iteration 1
PIMPLE: iteration 2
FOAM exiting
I'm sorry, I'm not very familiar with the sonicFoam solver. When NaN are generated it generally it means that something is going deeply wrong.
What I did not get at the beginning is that both of you are using a Windows version of OpenFOAM. Did you try on Linux? Or maybe use a docker image.
Old   January 25, 2018, 13:17
Foad
I solved the issue and you may see more info here in the OpenFOAM google group. There was actually nothing wrong with my code/model. it was just the model not converging due to the a very high input velocity. At least this was my issue. I'm not sure about the OP though!
Old   January 25, 2018, 13:28
rdbisme's Avatar
Ruben Di Battista
Always check BCs...
Old   January 25, 2018, 13:29
Foad
Originally Posted by tidusuper91 View Post
Always check BCs...
sure. novice here
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
