2D Waveflume:Bad waves due to symmetryPlane + k-epsilon?
Old   June 1, 2016, 10:08
Exclamation Turbulence settings in 2D Waveflume
mo_na's Avatar
Mona
mo_na is on a distinguished road
Hey guys,
I am trying to simulate a pitching floater in a 2D waveflume with ihDyMFoam.
For now I am simulating the flume without the floater and with ihFoam because I had problems with the waves just disappearing on the way.
The wave has the following properties:
IH Wave Generation BC
Wave theory: StokesII
H: 0.06
T: 1
h: 0.775
L: 1.55536
Direction: 0º
Generation in: Intermediate waters.
Relative depth (kh): 3.13076
I simulated 3 different cases:
*1* laminar case with front and backside empty
*2* turbulent case with front and backside empty
*3* turbulent case with front and backside symmetryPlane
I attached a plot of the amplitude over space for all three cases after 20s. Actually I realized that even the laminar case doesn't look that good, so probably I have some mistake in my fvSchemes, fvSolution or IHWavesDict.
But anyway the results are getting much worse when I add turbulence, especially for case *3*.
On the waves2foam thread Niels wrote:
" Well the short answer is yes that turbulence models have been coupled with waveFoam, however, if you strictly stick to the turbulence formulations in OpenFoam, you will get poor results, as the turbulence formulation in OF does not consider the density in the equations, hence excessive diffusion of turbulence takes place over the interface, which results in rapid decay in the wave height.
Therefore, you need to formulate the turbulence equations correctly, namely including density in the turbulence equations. "
Could this be the reason? Will I face the same problems when using ihFoam?
I'll be grateful for any suggestions!
Cheers,
Mona
IHWavesDict:
waveType        regular;
waveTheory      StokesII;
genAbs          1;
absDir          0.0;
nPaddles        1;
wavePeriod      1.0;
waveHeight      0.06;
waveDir         0.0;
wavePhase       0.0;
tSmooth         0.0;
fvSchemes:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rhoPhi,U)  Gauss limitedLinearV 1;
    div(U)  Gauss linear;
    div((rhoPhi|interpolate(porosity)),U)  Gauss limitedLinearV 1;
    div(rhoPhiPor,UPor)  Gauss limitedLinearV 1;
    div(rhoPhi,UPor)  Gauss limitedLinearV 1;
    div(rhoPhiPor,U)   Gauss limitedLinearV 1;
    div(phi,alpha)  Gauss vanLeer01;
    div(phirb,alpha) Gauss interfaceCompression;
    div((muEff*dev(T(grad(U))))) Gauss linear;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div((phi|interpolate(porosity)),k)      Gauss upwind;
    div((phi|interpolate(porosity)),epsilon) Gauss upwind;
    div(phi,omega) Gauss upwind;
    div((phi|interpolate(porosity)),omega) Gauss upwind;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha.water;
fvSolution:
solvers
    "alpha.water.*"
        nAlphaCorr      1;
        nAlphaSubCycles 2;
        alphaOuterCorrectors yes;
        cAlpha          1;
        MULESCorr       no;
        nLimiterIter    3;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-8;
        relTol          0;
    pcorr
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-5;
        relTol          0;
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-07;
        relTol          0.05;
    p_rghFinal
        $p_rgh;
        relTol          0;
    U
        tolerance       1e-06;
        relTol          0;
    "(U|k|epsilon)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-06;
        relTol          0;
    "(U|k|epsilon)Final"
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
PIMPLE
    momentumPredictor   no;
    nOuterCorrectors    1;
    nCorrectors         3;
    nNonOrthogonalCorrectors 0;
relaxationFactors
    fields
    equations
        ".*" 1;
mo_na is offline   Reply With Quote
Old   June 8, 2016, 09:14
Lightbulb Reflection issue?
mo_na's Avatar
Mona
Hey guys,
I added a new case *4* that is exactly the same as case *3* but I adjusted maxCo and maxAlphaCo both to 0.2 in the controlDict. This shows some improvements to case *3*.
I also plotted the first 10 seconds (see attachments) which makes me think that I did something wrong with the outlet boundary. It seems like the waves are reflected there.
This are my outlet BC in the 3D case:
U:
    outlet
        type            IH_3D_3DAbsorption_InletVelocity;
        nPaddles        1;
        nEdgeMin        0;
        nEdgeMax        0;
        value           uniform (0 0 0);
alpha.water, k and epsilon:
    outlet
        type            zeroGradient;
nut:
    outlet
        type            calculated;
        value           uniform 0;
p_rgh:
    outlet
        type            fixedFluxPressure;
        value           uniform 0;
Old   June 8, 2016, 09:15
Default Reflection issue?
mo_na's Avatar
Mona
heres the plots for second 6-10
ihfoam, kepsilon, symmetryplane, twodimensional, wave
Jump in epsilon values near the wall : low re k-epsilon model malaboss OpenFOAM Verification & Validation 1 February 1, 2013 17:36
Convectional term -fvm::Sp(fvc::div(phi_), epsilon_) in RNGkEpsilon OF 1.7.1 missing makaveli_lcf OpenFOAM Running, Solving & CFD 11 July 20, 2012 12:06
Large Epsilon 3D lepsilon Main CFD Forum 0 July 10, 2012 11:43
Compressible epsilon blows up swahono OpenFOAM 10 November 26, 2010 06:38
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
