June 1, 2016, 06:37 |
Reynolds number in 2D airfoil simulation
Rep Power: 10 |
i already talked about my problem in another thread called "airfoil pressure coefficient in pisoFoam kOmegaSSt". I have to analyse the separation position of a NACA 4412 airfoil. For that i want to calculate the pressure coeffient. But the cp value at the trailing is to small. I nearly checked every possible sources of error (mesh, /system-files, simulation with and w/o wallfunctions ...). Yesterday i found a cp-plot similar to mine in the following book: "https://books.google.de/books?id=5JaiBgAAQBAJ&pg=PA464&lpg=PA464&dq=druckv erteilung+naca4412&source=bl&ots=1KpjMcSVLh&sig=cW iqjot0_tyevA_tcJt7b5ugH58&hl=de&sa=X&ved=0ahUKEwiH q7fqo4TNAhXFaRQKHSLxDEgQ6AEIIzAB#v=onepage&q=druck verteilung%20naca4412&f=false" I know the dependency of the Reynolds number on the pressure coefficient but i wanted to check it. Yesterday i made 3 calculation. All of them with a velocity of 27.13 m/s, a viscosity of nu=1.5e-5 m^2/s but with a converttometers of 0.1,1 and 10. According to that 3 different Reynolds numbers of 1.8e+5, 1.8e+6 and 1.8e+7 and so different pressure coefficients. But in the results the cp-plots were nearly identical. Is it possible that i'm calculating with a wrong Reynolds number? Where do i have to change something? My airfoil geometry is from 0 to 1. Regards Claus |
June 2, 2016, 07:41 |
#2 | |
Otto Drissen
Rep Power: 10 |
The pressure coefficient is not a good parameter to detect flow separation. To detect the separation point you should use Cf. HTML Code:
http://www.cfd-online.com/Wiki/Skin_friction_coefficient P.S.: If your angle of attack is moderate, your TE not too thick and your flow low subsonic, I'd rather use X-foil for this task. |
June 3, 2016, 04:56 |
Rep Power: 10 |
No i mean the other way around.
If you change the Reynolds number there is a big influence on the pressure coefficient. But this dependency does not exist in my simulation and this must be wrong. I will try to do both ways of separation detection, cp and Cf. |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 13:01 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 15:49 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 09:14 |
Simulation of 0021 airfoil at 120,000 Reynolds number | AUCH | FLUENT | 0 | September 25, 2013 00:05 |
Reynolds number in 2D simulation | Wotild | Main CFD Forum | 7 | November 10, 2010 09:15 |
