compiling error(s) in interFoam (IOobject: volScalarField p_rgh not Stored) |
May 30, 2016, 15:24 |
Milad
Rep Power: 10 |
Hi every one
I'm new to openfOAm and I want to run k-e in simple open channel. I,m using openfoam 2.4 and this error (s) rise up: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : interFoam Date : May 30 2016 Time : 22:24:40 Host : "asus-G56JK" PID : 3559 Case : /home/asus/Desktop/RunningNewPracticeCleaned nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Reading g Calculating field g.h No finite volume options present time step continuity errors : sum local = 1.3439e-05, global = 9.59928e-06, cumulative = 9.59928e-06 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 8.34852e-06, No Iterations 15 GAMG: Solving for pcorr, Initial residual = 0.129927, Final residual = 5.87487e-06, No Iterations 8 GAMG: Solving for pcorr, Initial residual = 0.0118803, Final residual = 8.83448e-06, No Iterations 6 time step continuity errors : sum local = 3.65435e-10, global = 5.91482e-12, cumulative = 9.59928e-06 Courant Number mean: 0.000636646 max: 0.0144662 Starting time loop Courant Number mean: 0.000636615 max: 0.0144654 Interface Courant Number mean: 0 max: 0 deltaT = 5.99952e-06 Time = 5.99952e-06 PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 5.72698e-06, Final residual = 4.42909e-13, No Iterations 1 Phase-1 volume fraction = 0.459096 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.459096 Min(alpha.water) = 0 Max(alpha.water) = 1 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0237197, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.00233473, Final residual = 4.3589e-05, No Iterations 3 GAMG: Solving for p_rgh, Initial residual = 0.000706746, Final residual = 6.72664e-07, No Iterations 7 --> FOAM FATAL ERROR: previous iteration field IOobject: volScalarField p_rgh "/home/asus/Desktop/RunningNewPracticeCleaned/0" not stored. Use field.storePrevIter() at start of iteration. From function GeometricField<Type, PatchField, GeoMesh>::prevIter() const in file /home/openfoam/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/GeometricField.C at line 828. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::prevIter() const at ??:? #3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::relax(double) at ??:? #4 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::relax() at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Aborted (core dumped) Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 10e5; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } wall { type zeroGradient; } atmosphere { type totalPressure; p0 uniform 10e5; U U; phi phi; rho none; psi none; gamma 1; value uniform 0; } } // ************************************************************************* // |
compiling error(s), interfoam, previous iteration field, p_rgh |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 06:49 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
