Do different openfoam versions have different formats of the configuration files? |
May 30, 2016, 11:14 |
Suryansh D Kumar
Rep Power: 10 |
Hi
I am an absolute beginner to OpenFOAM. I tried running this snappyHexMesh tutorial which was run on version 2.3. I tried running it on version 3.0.1 http://calumdouglas.ch/openfoam-tuto...comment-169285 I tried running the same example, using the exact same instructions as given in the attached file using OpenFOAM 3.0.1 but got some errors. Do we need to follow any different instructions while using 3.0.1? This is the error I got ************************************************** ****************************** Unknown TurbulenceModel type RASModel************************************************** ****************************** I find it peculiar that it is searching for the C file in my home directory but OpenFOAM is installed in root. Is this the cause of error? On changing the constant/turbulenceProperties file to laminar, I still get an error ************************************************** ***************************** Selecting incompressible transport model Newtonian************************************************** **************************** Any help would be greatly appreciated. Thanks in advance. |
openfoam 2.3, openfoam 3.0.1, snappy hex mesh |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
[Other] Which versions of OpenFoam and Paraview are suitable for Ubuntu 14.04 LTS Trusty Tahr | Asghari_M | OpenFOAM Installation | 4 | February 4, 2015 16:47 |
PC configuration for OpenFOAM | Ruli | Hardware | 3 | October 6, 2013 11:31 |
OpenFOAM v.2.x Courant Number 4 time higher then in previous versions | makaveli_lcf | OpenFOAM Running, Solving & CFD | 8 | February 18, 2012 22:28 |
Can't get older versions of OpenFOAM | fabioc | OpenFOAM Installation | 4 | February 7, 2012 10:13 |
