pimpleDyMFoam,parallel,area does not match neighbour |
LOU Lida
Rep Power: 11 ![]() |
Dear Foamers,
I was using pimpleDyMFoam to simulate some dynamic mesh case. My case can run in serial but not in parallel. Code:
Time = 0.0001 Inverting RBF motion matrix volume continuity errors : volume = 63.99998804, max error = 0, sum local = 0, global = 0 smoothSolver: Solving for Ux, Initial residual = 0.9999999697, Final residual = 1.940639766e-06, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.009113619622, No Iterations 10 DICPCG: Solving for p, Initial residual = 0.1448696186, Final residual = 0.001360322043, No Iterations 12 DICPCG: Solving for p, Initial residual = 0.03288304611, Final residual = 0.0003125233115, No Iterations 29 time step continuity errors : sum local = 1.062426731e-09, global = -8.417019943e-11, cumulative = -8.417019943e-11 Moving mesh time step continuity errors : sum local = 1.062426731e-09, global = -8.417019943e-11, cumulative = -1.683403989e-10 DICPCG: Solving for p, Initial residual = 0.01141814687, Final residual = 0.0001126015515, No Iterations 40 DICPCG: Solving for p, Initial residual = 0.004746542347, Final residual = 4.588051877e-05, No Iterations 92 DICPCG: Solving for p, Initial residual = 0.004053370021, Final residual = 0.0003471630065, No Iterations 2 time step continuity errors : sum local = 1.223790396e-09, global = 1.079705363e-12, cumulative = -1.672606935e-10 Moving mesh time step continuity errors : sum local = 1.223790396e-09, global = 1.079705363e-12, cumulative = -1.661809881e-10 smoothSolver: Solving for Ux, Initial residual = 6.683720577e-05, Final residual = 4.632345119e-10, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.001679268542, Final residual = 1.645379057e-05, No Iterations 51 DICPCG: Solving for p, Initial residual = 0.001234871242, Final residual = 1.192388694e-05, No Iterations 11 DICPCG: Solving for p, Initial residual = 0.0003613903132, Final residual = 3.483720583e-06, No Iterations 59 time step continuity errors : sum local = 1.236435531e-11, global = -2.547561024e-12, cumulative = -1.687285492e-10 Moving mesh time step continuity errors : sum local = 1.236435531e-11, global = -2.547561024e-12, cumulative = -1.712761102e-10 DICPCG: Solving for p, Initial residual = 0.000356150859, Final residual = 3.559849006e-06, No Iterations 62 DICPCG: Solving for p, Initial residual = 0.0004029486792, Final residual = 3.729478687e-06, No Iterations 12 DICPCG: Solving for p, Initial residual = 0.0001090817749, Final residual = 7.626294024e-06, No Iterations 2 time step continuity errors : sum local = 2.706125338e-11, global = 2.824445213e-12, cumulative = -1.68451665e-10 Moving mesh time step continuity errors : sum local = 2.706125338e-11, global = 2.824445213e-12, cumulative = -1.656272198e-10 ExecutionTime = 16.72 s ClockTime = 17 s Courant Number mean: 5.566444905e-07 max: 0.0001664760881 velocity magnitude: 0.01569961157 forces output: forces(pressure, viscous)((0 0 0) (0 0 0)) moment(pressure, viscous)((0 0 0) (0 0 0)) forceCoeffs output: Cd = 0 Cl = 0 Cm = 0 Time = 0.0002 [0] [0] [0] --> FOAM FATAL ERROR: [0] face 3013 area does not match neighbour by 0.12569% -- possible face ordering problem. patch: procBoundary0to1 my area: 1.24799e-06 neighbour area: 1.24642e-06 matching tolerance: 0.0001 Mesh face: 551216 vertices: 3((0.00971941 -0.0168322 -0.0854581) (0.00981709 -0.0153605 -0.0854373) (0.00850303 -0.0162224 -0.0843145)) Rerun with processor debug flag set for more information. [0] [0] From function processorPolyPatch::calcGeometry() [0] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 217. [0] FOAM parallel run exiting [0] [1] --> FOAM FATAL ERROR: [1] face 3013 area does not match neighbour by 0.12569% -- possible face ordering problem. patch: procBoundary1to0 my area: 1.24642e-06 neighbour area: 1.24799e-06 matching tolerance: 0.0001 Mesh face: 711111 vertices: 3((0.00971941 -0.0168322 -0.0854581) (0.00850303 -0.0162224 -0.0843145) (0.00981098 -0.0153605 -0.0854373)) Rerun with processor debug flag set for more information. [1] [1] From function processorPolyPatch::calcGeometry() [1] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 217. [1] FOAM parallel run exiting [1] [3] [3] [3] --> FOAM FATAL ERROR: [3] face 128 area does not match neighbour by 0.0344233% -- possible face ordering problem. patch: procBoundary3to2 my area: 2.55386e-07 neighbour area: 2.55474e-07 matching tolerance: 0.0001 Mesh face: 548575 vertices: 3((0.00972533 -0.00624834 -0.0735605) (0.00928942 -0.00670668 -0.0732511) (0.00881222 -0.00615683 -0.0732511)) Rerun with processor debug flag set for more information. [3] [3] From function processorPolyPatch::calcGeometry() [3] in file [2] [2] [2] --> FOAM FATAL ERROR: [2] face 128 area does not match neighbour by 0.0344233% -- possible face ordering problem. patch: procBoundary2to3 my area: 2.55474e-07 neighbour area: 2.55386e-07 matching tolerance: 0.0001 Mesh face: 708031 vertices: 3((0.00972533 -0.00624834 -0.0735605) (0.00881186 -0.00615683 -0.0732511) (0.00928942 -0.00670668 -0.0732511)) Rerun with processor debug flag set for more information. [2] meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 217. [3] FOAM parallel run exiting [3] [2] From function processorPolyPatch::calcGeometry() [2] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 217. [2] FOAM parallel run exiting Code:
FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 4 ( wing { type wall; nFaces 26996; startFace 2442294; } front { type wall; nFaces 10638; startFace 2469290; } back { type wall; nFaces 10613; startFace 2479928; } side { type empty; nFaces 42549; startFace 2490541; } ) // ************************************************************************* // BTW, I am using Foam-extend 3.1 Thanks, Lida |
LOU Lida
can anyone help??
dynamicmesh, openfoam |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 11 | September 4, 2024 04:28 |
[snappyHexMesh] Error while running SnappyHex in parallel | mg.mithun | OpenFOAM Meshing & Mesh Conversion | 1 | February 10, 2016 13:13 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation | peterputer | ANSYS Meshing & Geometry | 0 | May 15, 2012 08:53 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 22:50 |
