TKE budget dissipation in LES
Old   May 29, 2016, 14:23
Default TKE budget dissipation in LES
Balajee
bala_gk1988 is on a distinguished road
Hi
I need some help with calculating dissipation component of TKE budget from LES data. Other components of the TKE budget compares well with the experimental data. But the dissipation component is only half as that of the experiments.
In this paper by Bogey and Bailly http://citeseerx.ist.psu.edu/viewdoc...=rep1&type=pdf , they have calculated the total dissipation by adding both the filtering dissipation[explicit filter] and eddy viscosity dissipation[sgs model].
So, with OpenFOAM using implicit filtering, am I right in assuming that the difference in dissipation is actually due to the implict filtering [numerical discretization]. Is it acceptable. If so, is it possible to calculate this explicity.
I am using standard smagorinsky as SGS model.
bala_gk1988 is offline   Reply With Quote
Old   July 9, 2016, 05:51
Ehsan Asgari
syavash is on a distinguished road
Originally Posted by bala_gk1988 View Post
Hi
May I ask that how you calculate dissipation in OpenFOAM? Do you implement some utility?
Thanks
syavash is offline   Reply With Quote
dissipation, les, tke budget
TKE budget estimation by k-epsilon model pd.iiest FLUENT 1 March 12, 2016 12:25
Eddy Dissipation Rate for LES rsin CFX 13 September 3, 2015 13:20
TKE budget equation in LES doctorWho Main CFD Forum 3 March 12, 2014 12:27
What is really SGS dissipation term in LES? mrf6166 Main CFD Forum 0 January 5, 2014 07:57
Turbulent Eddy Dissipation in LES Patrick CFX 8 July 12, 2006 03:44
