Simulating Rotor-Stator coupling steady state |
May 28, 2016, 07:20 |
Jack
Rep Power: 11 |
I am running OpenFoam 3.0.0 and what I have is a mesh that I have merged from two separate meshes, one for a single rotor passage and one for a stator passage. I wish to run some steady RANS on this case to start with and the problem I am having is dealing with the fact that the number of stator blades is not an integer multiple of the rotor blades. Example I have 6 rotor blades and 9 stator blades. Hence my rotor outlet boundary is not the same area as the stator inlet boundary. In the literature this is referred to as a pitch change, and the solver must deal with the fact that the mass flow rate will change across the interface by the same ratio as the change in pitch (in order to conserve the same total mass flow rate for the full 360 degree machine). How can I deal with this? I am attempting to use the cyclicAMI boundary condition but it seems this requires the boundaries to have equal area?
I am hoping this can be done in OpenFoam 3.0.0! I have looked at OF 3.2-ext but the examples there are very different from what I am used to. I would be happy to share my case if anyone thinks they could help/benefit from seeing it. Thank you for your time. |
ami, boundary condition, rotor stator interface |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
POPULATION BALANCE MODELING (PBM) in Steady State | osha | Fluent Multiphase | 1 | June 18, 2022 08:22 |
Time step dependence of convergence behavior of steady state simulations in CFX | Chander | Main CFD Forum | 5 | December 23, 2013 06:31 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 15:37 |
