May 27, 2016, 12:17 |
MRF solving issues
carno
Rep Power: 17 |
Hi, I am new to openFOAM. Excuse me if I do any mistake.
I am trying to solve a MRF problem as below. The problem is the run is not able to complete even 10 iterations. I tried following, 1. Slowly ramping the speed to 3000 rpm 2. Initially tried to solve laminar and switch to turbulence to model k-w and k-e Nothing seems working. My problem details are as below. Meshcheck reports 1 error, Mesh stats points: 244533 faces: 2365063 internal faces: 2148809 cells: 1128468 faces per cell: 4 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 3 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 1128468 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 854 460 ok (non-closed singly connected) outlet 1184 630 ok (non-closed singly connected) walls 18276 9585 ok (non-closed singly connected) walls_stator 135500 68219 ok (non-closed singly connected) walls_rotor 60440 30311 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-3.588227 -1.183531 -1.183531) (3.094186 1.183531 1.183531) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.01979e-016 -1.406094e-016 -5.540091e-017) OK. Max cell openness = 3.759495e-016 OK. Max aspect ratio = 79.51179 OK. Minimum face area = 1.717113e-007. Maximum face area = 0.02271197. Face area magnitudes OK. Min volume = 1.808659e-010. Max volume = 0.001020305. Total volume = 23.12361. Cell volumes OK. Mesh non-orthogonality Max: 87.8478 average: 18.20694 *Number of severely non-orthogonal (> 70 degrees) faces: 389. Non-orthogonality check OK. <<Writing 389 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 5.490139, 2 highly skew faces detected which may impair the quality of the results <<Writing 2 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End ---------------------------------------- Solver exits doing following, Time = 2 DILUPBiCG: Solving for Ux, Initial residual = 0.3260528, Final residual = 0.0108277, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.3300664, Final residual = 0.01127371, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.3395786, Final residual = 0.01083639, No Iterations 2 GAMG: Solving for p, Initial residual = 0.08636129, Final residual = 0.004401122, No Iterations 7 GAMG: Solving for p, Initial residual = 0.1115448, Final residual = 0.005344135, No Iterations 1 time step continuity errors : sum local = 0.3802423, global = 0.003882829, cumulative = 0.007101267 DILUPBiCG: Solving for epsilon, Initial residual = 0.1713729, Final residual = 0.0156289, No Iterations 1 bounding epsilon, min: -156432.1 max: 3702708 average: 391.6643 DILUPBiCG: Solving for k, Initial residual = 0.4867903, Final residual = 0.04814626, No Iterations 2 ExecutionTime = 32.645 s ClockTime = 32 s Time = 3 DILUPBiCG: Solving for Ux, Initial residual = 0.4354033, Final residual = 0.02818809, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.7221585, Final residual = 0.05162595, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.4768465, Final residual = 0.04278764, No Iterations 1 GAMG: Solving for p, Initial residual = 0.1660247, Final residual = 0.0114165, No Iterations 2 GAMG: Solving for p, Initial residual = 0.03848046, Final residual = 0.002525837, No Iterations 3 time step continuity errors : sum local = 1.865936e+011, global = 9.781742e+007, cumulative = 9.781742e+007 DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.01480226, No Iterations 4 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.07233552, No Iterations 2 ExecutionTime = 46.764 s ClockTime = 46 s Time = 4 DILUPBiCG: Solving for Ux, Initial residual = 0.6965265, Final residual = 0.02627963, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.6764134, Final residual = 0.03492312, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.8239209, Final residual = 0.0755949, No Iterations 1 GAMG: Solving for p, Initial residual = 0.9999998, Final residual = 6.538528, No Iterations 100 GAMG: Solving for p, Initial residual = 0.0003485187, Final residual = 2.777873e-005, No Iterations 3 time step continuity errors : sum local = 6.827751e+025, global = -3.92473e+023, cumulative = -3.92473e+023 DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.05536559, No Iterations 15 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.08238156, No Iterations 3 ExecutionTime = 98.659 s ClockTime = 98 s |
May 27, 2016, 17:00 |
#2 | |
Arsalan
Rep Power: 12 |
As you said, the checkMesh command report an error from your mesh which is related to max skewness of two cells, and the solver crashes because of high continuity errors (the bold parts of the report) that arise probably from the low quality mesh. So you can give more details of your problem to get a more accurate help. Regards, Arsalan. |
May 30, 2016, 05:54 |
carno
Rep Power: 17 |
Thanks, Arsalan. I also think it is mesh issue. I will work on it. I used salome for tet-meshing.
I am sending other details also. The rotor diameter is around 2.2m You might have figured out that from bounding box. I am using k-w turbulence model. Inlet: total pressure, Outlet: static pressure Attaching solver files. fvSchemes file Code: FoamFile { version 2.0; class dictionary; format ascii; location "system"; object fvSchemes; } ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default bounded Gauss upwind; div(phi,U) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(R) Gauss linear; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } fvSolution file Code: FoamFile { version 2.0; class dictionary; format ascii; location "system"; object fvSolution; } solvers { U { tolerance 1.0E-6; preconditioner DILU; solver PBiCG; relTol 0.1; maxIter 100; } epsilon { tolerance 1.0E-6; preconditioner DILU; solver PBiCG; relTol 0.1; maxIter 100; } omega { tolerance 1.0E-6; preconditioner DILU; solver PBiCG; relTol 0.1; maxIter 100; } k { tolerance 1.0E-6; preconditioner DILU; solver PBiCG; relTol 0.1; maxIter 100; } p { nPostSweeps 1; solver GAMG; smoother GaussSeidel; nFinalSweeps 0; nPreSweeps 0; nCellsInCoarsestLevel 100; cacheAgglomeration true; maxIter 100; tolerance 1.0E-6; agglomerator faceAreaPair; relTol 0.1; mergeLevels 1; } } SIMPLE { nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0.0; residualControl { U 1.0E-4; epsilon 1.0E-4; k 1.0E-4; p 1.0E-4; } } relaxationFactors { U 0.7; epsilon 0.8; k 0.8; p 0.3; } potentialFlow { nNonOrthogonalCorrectors 10; pRefCell 0; pRefValue 0.0; } |
continuity error, solver control, turbulence models |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
