May 25, 2016, 18:57 |
Velocity jump at outlet edge
chubb87
Rep Power: 15 |
I am simulating a journal bearing and the velocity at the outlet boundary looks strange: At the edge of the outlet (see picture) at the moving wall there is a sudden jump in the velocity from 8 m/s to 60 m/s, which occurs only in one cell layer next to the moving wall patch (which is moving with 8 m/s to the left) and seems to be unphysical. I suspect the reason might be the boundary conditions, which are as follows: At outlet: p - fixedValue U - zeroGradient at moving wall: p - zeroGradient U - movingWallVelocity And at the symmetry of course symmetry condition. This jump in velocity is most pronounced at the wall meeting the symmetry patch and the outlet (where backflow occurs). Unfortunately I do not know which boundary conditions might be a better choice for the outlet. Can you give me advice? Thanks in advance. |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
changing velocity (outlet) BC to pressure outlet | majid_kamyab | FLUENT | 7 | October 22, 2014 11:50 |
time varying velocity outlet boundary condition | simin_ds | OpenFOAM | 3 | September 12, 2014 02:13 |
a standard method of determining the outlet velocity? | mutata | ANSYS | 0 | June 10, 2012 12:23 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
